Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 01-16-2005, 04:35 PM
Kmed is on a distinguished road
4-5 axis control recomendations for home built horizontal machine
Well I figured I would ask what some are using for thier 4-5 axis machines for controls. I am finishing up the design / plans for my home built horizontal machine.
Just curious. I have selected most other items already. Havent spent any time on control choices.
Old 01-17-2005, 12:48 PM
No one? Well some specs at the least..
-travels XYZAB 8X16X10 A ROTARY 380 degrees / B ROTARY continuous
-Cast Iron base hardened machined and mating surfaces ground (3200 lbs) (old right angle from a crane).
-356 Cast aluminum ways hardned and ground
-Full enclosure with chip auger (part of small ice auger, with sheet metal shroud)
-Plexi view windows.
-Single 3 position tombstone with fixture plates ( for adding 5th axis, kurt 3600 vise or kurt modular vise systems.
-Brushless 11000 mNm, 5400 rpm servos (24v) with built in encoders (0-5v).
-Precise 10,000-40,000 spindle iso20 tool holders, hydralic drawbar (future addition of tool changer)
-Precision ground 25mm High Pitch ball screws w/anti backlash nuts
- NSK 28mm Liner rails and bearings
-Way covers (Still figuring them out did not leave myself much room)
Machine should be able to run 300-400 IPM rapids and 200-300 IPM cutting.
Hopefully it will be solid enough to run a 3/8 endmill at 1/2 DOC and 100-150 ipm.
Old 01-17-2005, 01:49 PM
Al_The_Man's Avatar
Depends what you want to spend, two systems that will do all of that Camsoft/Galil & Acroloop/MotionMax.
Al
Old 01-17-2005, 04:04 PM
Well I have actually looked into camfsoft for a retrofit, and did not even think of it this time. I am not familiar with the acroloop / motionmax any more info?
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 03:08 PM
5 axis control system need suggestions pab Commercial CNC Wood Routers 6 02-06-2005 10:58 PM
Need suggestions on components 5 axis control system? pab Mach Software (ArtSoft software) 0 01-19-2005 04:34 PM
5th even 6th axis? how does it work ToMMY2ooo General Metal Working Machines 10 10-04-2004 03:58 PM
2 axis linear machine control ? vostryc General CNC (Mill and Lathe) Control Software (NC) 2 09-05-2004 07:30 PM
