Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 03-28-2009, 10:46 AM
Stephenwinter is on a distinguished road
Boss 8 Bridgeport Mill series II
Ok, I am trying to get the mill to execute a very small g code text so later I hope to drip feed it. The name of the text file is 1234.txt and the first line in the file is :1234 . I cannot get the Boss to load the file. I am sure I am sending to the Boss because I have Leds (with resistors) on the serial cable to show data traffic.
Com 1
Baud 300 (so I can see the lights blink when I send a file)
Data bits 7
Parity none
Stop bits 2
Flow Control xon xoff
I get a serial led light from the Boss when I turn power on. The Boss has been set to 300 baud on serial ports A and B. I connect the serial port on the computer to B on the Boss . The small LCD display on the Boss displays:
1) Wait
2) > Enable Axis Drives (I depress Axis Drive Enable button)
3)Move ZXY Home > Execute (I depress Execute button and the table goes home)
4) Boss 81 II (C) 1984 Textron Inc
5) I depress the Load Clear Edit button and get three choices and need to push number 0 or 1 or 2.
6) Load 0 Ptr 1 Dnc 2 Rem
Pressing 0 and then Execute cuts power to axis drives and produces the message Enable Axis Drives again
Pressing 1 and Execute produces Load DNC where what ever you enter produces Load DNC : (your entry).D
Pressing 2 and Execute produces Load Rem 0 From Rem 1 to Rem ( I select 0 and press Execute and produce
Load Rem:_ where any entry produces Load Rem: (your entry) . F
I have followed the manual to delete all programs and tool sets and still get the F.
So here is where I am stuck.
the machines talk but I get a dead end.
What do you think?
Steve Horn
Tags
boss 8 controller, bridgeport boss machine
bridgeport series 2 cnc boss 6 MR Custom Bridgeport and Hardinge Mills 27 12-22-2011 08:52 PM
bridgeport series 1 with boss 10 Minnesota HD 10 Bridgeport and Hardinge Mills 0 02-10-2009 11:32 AM
bridgeport series 1 boss 6 MR Custom Bridgeport and Hardinge Mills 11 11-19-2007 07:04 AM
Bridgeport Series I Boss 4 millwrightguy Bridgeport and Hardinge Mills 6 06-27-2007 08:07 PM
Bridgeport Series I Boss 5 Controller VIC H General Metal Working Machines 0 07-24-2006 11:54 AM
