Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 03-16-2009, 06:15 PM
mcash3000 is on a distinguished road
wear offset missing
i have a fanuc 18-M machining center that is missing the wear offset screen. it just has a offset screen numbered 1-200. Does anyone know how to turn on the wear offsets.
Old 03-20-2009, 08:21 AM
stevo1 is on a distinguished road
PM sent
Stevo
Old 03-20-2009, 12:01 PM
charger19690 is on a distinguished road
mcash3000
i am not completely sure, but older fanucs didn't have a wear offset on them, just a list of offsets which common practice in shops I have worked at was to use the "T" value as your "H" and add 50 to it and use that as your "D", example:
T1 would use H01 for the tool length offset
T1 would use D51 for cutter comp, the wear offset
They would be listed on the same one screen. The newest fanuc I was on was 20 something, and it did have a wear column on that one in the offset page. I am not sure about the 18-M though. It could have a wear column, but the +50 thing works too.
cncmike
http://www.cncbasics.com
http://www.cncbasicsforum.com
www.cncbasics.com www.mastercamforum.com
Old 03-20-2009, 12:27 PM
Just an FYI the 18m is a newerish model control that does support the wear offsets but they are Fanuc options.
Stevo
Old 03-20-2009, 12:35 PM
I see
Don't you love when you buy a machine, it already has the stuff in it, but you have to "Pay" to turn it on.
We had an old OM control once that had 16k of memory. Our Fanuc guy changed 1 parameter and we had 64k. Kinda makes me mad that the function is in the capital equipment when you purchase it but you can't use it.
It's like spending $30k for a brand new car and the dealer saying if you kick in another $1,000 I will unlock "Drive" for you, you really don't only want to drive around in 1st and 2nd do you?"
It's all a racket...
cncmike
Wear offset and writing parameters gollame Colchester Tornado lathes 2 10-28-2009 01:06 AM
Need Automatic Wear Offset p8md G-Code Programing 13 10-24-2008 10:28 AM
Need Help!- Fanuc O-T Wear Offset Parameter gollame General CNC (Mill and Lathe) Control Software (NC) 4 03-10-2008 07:40 PM
Wear offset and writing parameters Fanuc gollame General CNC (Mill and Lathe) Control Software (NC) 0 03-03-2008 04:15 AM
Missing something... using edge finder thingy in offset screen... InspirationTool Mach Mill 10 04-01-2007 03:13 PM
