Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 03-03-2009, 12:51 PM
napa55 is on a distinguished road
help spindle does't turn
When I first start a program, the spindle doesn't run. If I run the program for about 5-10 min it starts to run. It has 3 phase going to the inverter plus the 0-10 volt signal.
Need Help!- G-Code to turn on and off router, non-spindle Sam A G-Code Programing 6 10-24-2008 09:02 PM
T1..why does the spindle not turn? carbidecraters Mazak, Mitsubishi, Mazatrol 1 09-05-2008 10:32 PM
Need Help!- spindle wont turn jkinz56 Milltronics 8 06-26-2008 12:17 PM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 06:51 PM
BP Series 1 CNC- spindle won't turn on MDA40 Bridgeport and Hardinge Mills 3 11-08-2004 09:05 PM
