Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
  #13   Ban this user!
Old 10-31-2009, 11:01 PM
dovi is on a distinguished road
802c
I found the 802c in china at about 2000$US including shipment. what I'm worried about is lack of support here . No one has used it here before and ther is no local technical support .
I plan to use it on a vertical CNC lathe instead of a old Allen Bradley control. Thr Axes Servo , also AB I plan to use as is and same for the spindle. I hope this is going to be a simple ,almost plug and play exept for the PLC.
If this goes right w will offer it for simple milling machines etc.
Did you do any further machines with it? What were your costs for the control?Which warrantee did you get? Where did you get the support from?
regards
Dovi
  #14   Ban this user!
Unread 05-26-2012, 12:23 AM
FAHJ is on a distinguished road
Originally Posted by dovi View Post
Hi - So did you use the 802c after all? how did you like it? how difficult was it to programm the PLC?
Please share your expriance with this retrofit
just to day i have been insatling and retrofeed 30 numbers the kinde of machine turning and milling with this system and all machines is working good.
Need Help!- Siemens (sinumerik 802C base line) Afzal Controller & Computer Solutions 2 08-15-2010 02:31 AM
Need Help!- Siemens 802C Htech General CNC (Mill and Lathe) Control Software (NC) 1 01-29-2009 04:57 PM
retrofitting CNC lathe prash General Metal Working Machines 4 09-20-2007 02:55 AM
Retrofitting with fanuc IN-WondeR Fanuc 1 08-20-2007 07:02 PM
Knee retrofitting m_c Knee Vertical Mills 10 02-27-2006 03:12 PM
