Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 02-04-2009, 08:47 PM
rktman8888 is on a distinguished road
Anilam 3300 mk or Mach III
What do you guys think. I just bought an 1999 Sharp TMV knee mill with Anilam 3300MK controller. Servo motors and ground ball screws. The machine and everything looks good. Very little use on it. Im so use to using Mach II and III with G320 drivers. Im wondering if it would make more since to stick with what I know. Abandon the 10 year old control system. It’s in good shape. I just don’t have a lot of time to learn a new system and get my PC to talk with it. Is there any performance advantage staying with an industrial Anilam type controller. Will Mach and G320's do the same job?
Thanks for any comments
Jeremy
Old 02-11-2009, 07:23 PM
JoeFin is on a distinguished road
The anilam will run another 10 yrs without too much trouble and a fairly large group of software engineers/mechanical engineers have done their best to idiot proof the control system's software.
For me it's a slum dunk - I'd keep the anilam and inveast in some good CAM software and starts making chips
Old 02-16-2009, 08:07 PM
thanks joe
Old 02-22-2009, 09:54 PM
elnerdo is on a distinguished road
I think you should think twice about abandoning a functional industrial control sytem for Mach. Most industrial control systems use a feedback system that makes use of a resolver and an encoder for the control loops. Drives run in velocity mode on one feedback loop and get wrapped with a position loop to the control system.
The strategy has advantages because the velocity is monitored independently of position. It works well when it comes to low speed linearity as well as using scales for feedback. (if you have them) You can/could put something like this together with EMC and possibly Mach but it would take more effort than learning the Anilam either way.
Find someone in your part of the woods that uses the Anilam and see if you can get a lesson on it. I think you'll save yourself alot of time in the long run.
Old 02-18-2010, 02:08 AM
Custom Billet is on a distinguished road
I had both. I started with the Anilam 3300. I bought an old Bridgeport and built the retrofit myself using the Mach motion control. The Mach worked good, but it was not as dependable. The Anilam is bullet proof. It just works.
I ended up selling off the Mach mill because I just didn't use it.
Old 09-12-2010, 04:47 PM
mhmedders is on a distinguished road
Anilam 3300
Will the Anilam 3300 mill 3d contour? An Anilam servo drive is over $800. Gecko is around $150. Service call for Anilam starts around $100 just to come out. Mach3 info is free. I'm not rich it a hobby.
Old 09-12-2010, 06:01 PM
Sure, it has no problem 3D milling.
The Anilam servo drive is $500. I had to buy one a few years back.
You get what you pay for. In my opinion, there is not a better retrofit control than the Anilam. Also, their tech support is great, but you have to have a little knowledge about how the control works. If you don't own a multimeter and don't have any understanding of electronics, they can't help much and it would be better to have them come out.
Old 09-12-2010, 06:21 PM
MrWild is on a distinguished road
Stick with what works. If it ain't broke, don't fix it.
Old 09-14-2010, 11:23 PM
Are you saying that the Anilam 3300 can cut 3D contour surfaceing? If so, How?
Old 09-19-2010, 12:57 AM
If my Crusader M control can do 3D, the 3300 will do it hands down .
  #11   Ban this user!
Old 09-21-2010, 03:17 PM
Toolbit is on a distinguished road
Jeremy,
Most people buy a software program such as Vetric, Bobcad, or master cam depending on how deep your pockets are to gererate a 3-d model and the cam part of the program with the right post processor will generate the correct code for your machine. Next if your controls memory is too small for the thousands of lines of code that will be gererated for 3-d. It will be necessary drip fed the code to your machine. Sounds like a lot but it really isn't all that difficult.
  #12   Ban this user!
Old 09-24-2010, 12:19 AM
I use MasterCam with Anilam1100 post. The controle converts gcode to conversation not sure why but I get error message like "unknown code" or something like that when the gcode uses Z and X and/or Y in the same line. Not sure if it's the post or some perameter in Anilam software. Any one got answers?
anilam 3300 mk hard drive died nealg General CNC (Mill and Lathe) Control Software (NC) 5 11-19-2010 12:50 PM
anilam 3300 help ninja11zx General Electronics Discussion 2 11-18-2010 01:21 PM
Anilam 3300 Post for Mastercam X Bryant303 Post Processor Files 6 12-10-2009 01:11 PM
installing anilam 3300 on supermax mill. ninja11zx General Metal Working Machines 2 05-02-2009 12:09 AM
Does any one have a EdgeCAM post for Anilam 3300 journeyonline Post Processor Files 0 03-31-2008 02:27 PM
