| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
I have a Yasnac MX3 controller on a Kitamura Mycenter I have a problem with it cutting too short of a path when using cutter comp G41 or G42 during a radius. I included the program which I am pretty sure is not an issue. I am just rounding the end of a 1" wide 1/2 thick piece if steel. Here is what happens. It is programed for a .520 radius with a compensation offset on D15 of .310, which should in fact create an actual machine position movement of 1.660 (.830 radius) along the Y axis, the machine moves a grand total of 1.5692. I did this cutting air so tool pressure is a non issue. I set the cutter comp on offset D15 to .000 and the thing moved 1.040 on Y (.520 radius) like it should. I also tried changing the cutter comp value from .310 to .320 expecting an extra .020 on the Y axis during the radius and I got an extra .0171. The X axis appears to behave itself. I have had this machine for 3 months and still debugging it. Is there a parameter that may be wrong? Thanks in advance for any suggestions. G91G28Z0 G20 G17G40G80G90 G53G0X-3.Y-3. T5 M6 (1/2 EM) G54G90G0X1.2Y-1.2S3000M03 G44 G41G17D15 G00X1.2Y-1.2 G1X.52Y-.52F20.0 G0Z1.0H5 Z.5M08 G1Z.1F50.0 G1Z-.6F20.0 G2X.52Y.52R.520F2.0 G1Z.1F20.0 G0Z1.0 G0Z2.0 G49 G40D0 M5 G91G28Z0 G53G0X-8.0Y-3. M30 |
| Newbie- Using cutter comp eia/iso on M2 | apylus444 | Mazak, Mitsubishi, Mazatrol | 8 | 10-09-2008 09:44 PM |
| Cutter comp on an id hole< cutter diam.?? | PaintItBlue | Haas Mills | 5 | 05-05-2008 07:30 PM |
| Need Help!- YASNAC LX-3 on METHODS Slant 50 Rapid Traverse issue! | ballchain | General CNC (Mill and Lathe) Control Software (NC) | 1 | 04-19-2008 10:11 AM |
| Cutter Comp? | donl517 | Fadal | 5 | 07-03-2007 09:36 AM |
| 18-it cutter comp | newcinhypro | Fanuc | 1 | 01-25-2006 09:00 PM |
