Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 09-08-2008, 08:14 AM
theguild is on a distinguished road
bridgeport R2E4
Hi,I'm having trouble with drip feed dnc link.Machine is shutting down. Axis drive error in middle of program.Shutting down in different spots of program.
Raised the baud rate to 9600 thought this would fix the problem did not.Not sure what to do.If anyone could help I would be very thankful.
THANKS,
KEITH
Old 09-08-2008, 11:23 AM
cut more is on a distinguished road
Drip feeding trouble
Keith,
I have an R2E3 and have trouble sometimes drip feeding. What are you using for software?
Probably, increasing the baudrate is not the way to go if you are having trouble.
The question is, are you getting an axis error from lost commands or from trouble with the axis. Is it always the same axis?
Cutmore
Old 09-08-2008, 11:50 AM
Cutmore,
I'm using e-link.I don't have trouble with program's unless I'm using dnc.
It's not an error from a certain axis. The machine stops and wants me to home it again.
I don't think it's a command because it stops in different spots in the program.
Thanks for the reply.
Keith
Old 09-08-2008, 12:45 PM
DNC trouble
Just a quick thought, Make sure your cable is not loose or possibly the wires frayed/broken. You probably checked that already, but it was just a thought.
I would try reducing the baud rate to something like 2400 and see if the problem goes away. That will tell you if it's a communication problem.
If the baud rate is too high, the computer could send the command to the bridgeport and the bridgeport could lose part of the command. Let's say the command is G54 G0 y-5, and the control lost the G54 part. The machine would possibly try to go too far and trip either a soft limit or hit a limit switch which would cause you to have to re-home.
Cutmore
Old 09-08-2008, 01:19 PM
tried it at 2400,1200,600 did not fix the problem.
any other thoughts?
thanks
Keith
Old 09-08-2008, 01:25 PM
DNC Trouble,
The only other thing I can think of is, is the pc you are using have a network connection? Maybe somethings happening when the pc looks to the network.
Other than that, I am stumped, Sorry.
Try posting in the Bridgeport section if you haven't already. There is also a forum for Bridgeports on Yahoo and the practical Machinist sites.
Cutmore
Old 09-18-2008, 08:54 PM
Fwd She is on a distinguished road
We had a Matsuura with the Yasnac mx3. Trying to feed from a brand new Epson laptop. The cnc machine was brand new also. Drove us crazy for almost a month. Machine mfg said it was us, controller mfg said it was us, computer mfg said it was us. After much ascerbic communications and much grudging help or checking from their reps turned out there was a crack in mx3 motherboard that affected only ourstide feeding. Fixed that, still didn't work. Epson reluctantly checked, guess what? crack in their motherboard. I am wondering if maybe yu have a cracked board someplace. I hope not.
Fwd She
Old 08-08-2009, 11:09 PM
asantos is on a distinguished road
Bridgeport R2E4 baud rate is 4800 do not send by usb port only 9 pins port....
Have a Nice day
Bridgeport R2E4 steve ohalloran Bridgeport and Hardinge Mills 11 06-21-2010 03:11 AM
Bridgeport R2E4 will not start synergymc Bridgeport and Hardinge Mills 7 07-31-2007 08:42 AM
bridgeport 9 r2e4 reedmiles Bridgeport and Hardinge Mills 4 06-22-2007 08:07 PM
bridgeport r2e4 najnielkp Bridgeport and Hardinge Mills 10 11-05-2006 04:42 PM
bridgeport 9 r2e4 reedmiles General CNC (Mill and Lathe) Control Software (NC) 0 12-30-2005 08:06 AM
