| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
I just ordered my K2 2525 it's coming with Mach3. I need some ideas on converting cad files to G-code. I'm only routing shapes from sheets of plastic, no 3D requirements. Can anyone help me decide what will work for my needs. I have Alibre and will probably use it to create the parts, but all of my originals were done in CorelDRAW V8. Thanks, Jim |
I downloaded gsimple and am trying to digest it. I'm only interested in routing shapes from plastic. I'm going to be using a 0.094 single flute micro100 bit. I'm so lost. I can see how lots of cool machining operations can be accomplished, but I don't see how this can convert a DXF drawing to G-code of routing the shapes. The part where it draws lines around an abject spaced away from the object where the distance is the radius of the cutting tool. Can it do that? I know I have a lot to learn, but if the program won't do it I'm spinning my wheels. Please help. Thanks, Jim |
| Never used it, so I don't know. But typically with free programs, you'll need to do the offset yourself in the CAD program. The center of the tool will usually follow the line in the .dxf.
| I found this real gem. CUT2D by Vectric, www.vectric.com It's perfect for my needs. It can load a DXF and it does the machine tool offset for you. Really nice 3D display as well. Cost, $149.00!!! |
| Mazatrol Program into a G Code Program | fuzzman | Mazak, Mitsubishi, Mazatrol | 14 | 02-08-2010 03:55 PM |
| Free (G-Code Program) Surface Router Table | Switcher | Visual Basic | 22 | 08-16-2009 03:00 PM |
| Solidworks to G-code, cheap or free | darryl | Solidworks | 1 | 11-08-2006 05:37 PM |
| Cheap or free CNC software | JFettig | General CAM Discussion | 9 | 12-05-2003 07:38 AM |
| cheap bitmap to gcode program | balsaman | DIY-CNC Router Table Machines | 29 | 07-28-2003 01:04 PM |
