Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 07-07-2008, 06:42 PM
GPena is on a distinguished road
Meldas 50 lathe T01 CAN'T CYCLE START 0104
We are having a problem with a lathe wiht Mitsubishi Meldas 50 controller, the problem is that as soon as we try to run a program in memory mode the alarm "T01 CAN'T CYCLE START 0104" appears on the alarm screen, the machine does'nt move at all, the same in MDI. In the manual says that the feed hold switch or a wire may be bad, but it is all fine; also the A-OP STP SIGNAL(automatic operation stop signal "on") but we can't find it in the ladder, any idea where to look????
Thank you.
GP.
Old 07-07-2008, 06:58 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Look for output Y219, this is the feed hold signal to the CNC. This signal must be ON in order to cycle start.
Regards,
Scott
Old 07-08-2008, 09:08 AM
Scott,
Thank you for your reply, I will check that today and as soon as I have something I will let you know.
GP.
Old 07-08-2008, 06:02 PM
Scott:
Yes, it was that signal. The problem was that the counter reached the maximum pieces, we found that in the ladder and solved the problem.
Thank you very much for your help.
Greg.
Old 07-14-2008, 03:29 PM
Constella_Gray is on a distinguished road
Hello,
I'm having the same problem with a similar controller but for milling. Tried looking for the output Y219 but there isn't one, just 218 and 220.
Does anyone have any solutions?
Thank You.
Gray@constella.
Old 07-14-2008, 09:10 PM
MetLHead's Avatar
Gold Member
Gray,
Is it the same problem and the same control? The signal Y218 is the cycle start signal and Y220 is NC Reset.
This is a link to the PLC Interface Manual, it's for the M64 but the M50 uses the same signal layout:
http://www.meau.com/functions/dms/ge...00000673500000
Scott
Old 07-15-2008, 08:08 AM
Thank you for the reply Scott,
It is a Mitsubishi controller with Meldas M3/L3 software. Its an oldie...
The problem came about after a toolchange, was going to face a block after testing a program, then the alarm T01 CAN'T CYCLE START 0104 came up.
Now it does even operate in Manual or MDI, any more help would be much appreciated,
Thanks again,
Gray@Constella
Old 07-15-2008, 08:52 AM
MetLHead's Avatar
Gold Member
Gray,
I can't imagine that your PLC would not include the Y219 signal. Here's how you can search for it using the onboard PLC tools:
1. Press the "F0" key, this takes you to the onboard PLC screen.
2. Press the "Ladder" softkey.
3. Press the "Circuit" softkey.
4. Press the "Read" softkey.
5. Type in "Y219" and press "Input".
If found, the rung containing the signal will appear. Pressing "Input" again will continue the search. You're looking for a rung that has the Y219 signal on the right hand side of the screen (as a coil). Once you find the coil you can press the "Monitor" softkey to show the status of the contacts in the rung. This signal will normally be ON.
Scott
Old 07-15-2008, 10:02 AM
Thats all ok,
Somehow it started up ok, but then the problem can back later on, starting to check the wiring, something may becoming loose as the machine vibrates on the tool change.
We're new to this machine and getting familiar with its 'character' is becoming a long process. 'Everyday is a learning day', haha,.
Thanks for helping.
Gray.
Cycle start not working - SL3B andy.f Mori lathes 10 02-15-2008 12:30 PM
Cycle Start output on Fanuc 15-MA davider Fanuc 3 02-14-2008 09:18 AM
Remote cycle start REVCAM_Bob Fanuc 6 03-18-2007 07:08 PM
Remote cycle start? REVCAM_Bob Fanuc 0 01-20-2007 10:59 AM
Cycle Start button kaleem1 Mach Software (ArtSoft software) 7 12-24-2005 02:05 PM
