| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| Mach3 Z-axis disable when not in use Hey, I've recently built my own CNC, and so far it's working fine. The only problem I've encountered is that the motor on my Z-axis gets seriously hot after about 20 minutes of machining. Too hot almost to touch, so it's getting into the range of temperatures I'm not comfortable with. The problem here ofcourse is that the Z-axis generally moves the cutter in position and then just sits there, soaking up the full 1.5A the driver supplies it with. I'm using a standard M8 leadscrew, so there's no real reason for the Z-axis stepper motor to actually be on when it's not being used. I'm pretty sure I've seen an option in Mach3 somewhere to disable steppers when they're not in use, but I can't seem to find it anymore... Any help would be much appreciated. Erant |
| Try using a lower voltage, which might limit higher speed, but also might run cooler. But "almost too hot to touch", isn't really all that hot for a stepper. Under 85°C should be fine, some can run up to 100°C.
| Current reduction for steppers Configuring the Mach3 software: from the main menu, select config\ports & pins select output signals tab scroll down to Current Hi/Low column 1, click to get green 'enable' check column 2, set to port #1 (or whatever port you're using) column 3, set to pin #1 column 4, click to get green 'active low' check |
| Thanks! The Current Hi/Lo worked a treat. I specially used a higher rated stepper on the Z-axis, I don't want to limit the current here. And seeing as my screw is 1,25mm pitch, I hardly think the Z-axis is going anywhere, even without the stepper holding it in place. Thanks again! |
| Need Help!- How to disable ac97sound? | Mr Bits | LinuxCNC (formerly EMC2) | 4 | 05-01-2008 06:25 PM |
| Need Help!- Disable FAPT F3T | Pxt | Fanuc | 1 | 02-27-2008 09:28 PM |
| Disable switches | swarfmacdaddy | Gecko Drives | 9 | 10-24-2007 03:28 AM |
| Disable with Mach | belli | Mach Plasma / Laser | 3 | 07-14-2007 04:53 PM |
| Gecko 201 disable? | LEWENZ | Gecko Drives | 6 | 01-12-2007 10:24 PM |
