Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 05-12-2008, 03:31 PM
archerks is on a distinguished road
Probe Digitize Question
Wasn't sure which forum to post this in...
I plan on using the 3D Scanning probe from my compucarve/carvewright with Mach3. Once I have done the scan and have the *.txt file, what software do I need to use to get this into a *.nc file?
Right now I need the cheapest way to convert the txt to nc - demo programs would be great. Once I determine that it will do what I need, I will be willing to sink a few dollars into the software.
Dave
Old 05-12-2008, 06:57 PM
ger21's Avatar
Use mach cloud to turn it into a mesh, and MeshCAM or Cut3D to create the code
Old 05-12-2008, 08:13 PM
Settings for the probe
What are some good settings to set the 3d probe settings in mach3?
I am trying to scan a dime first and have the settings of...
X .5
Y .5
Max Grid Increment .01
Probe Depth .05
Probe Clear .05
Probe Rate 100
Probe Ball .012
It seems to be working it went to the center of the dime and the probe is going up and down, but I expected a lot faster movement. It cycles about 1 down cycle every second. Is this correct or do I need to change some settings.
Dave
Wireless probe question rbest27 Haas Mills 3 03-28-2008 06:47 AM
Digitizing Probe Question Trainhound Digitizing and Laser Digitizing 1 01-05-2006 06:25 PM
Can anyone here digitize a part for me? Cold Fusion Employment Opportunity 11 10-21-2005 05:05 PM
DIY Digitize? Possible? artisanstone Digitizing and Laser Digitizing 3 06-03-2005 05:24 PM
software or digitize jmc General CAM Discussion 2 01-19-2005 11:27 PM
