| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| Please help if you can, A co-worker drafted a simple flat ring shaped part with an open center, 3 elongated slots at 120 degrees apart and 3 half circle bolt clearance holes also at 120 degree spacing, So I opened the part in MasterCAM X and now how do I get that software to look at the part features and generate the NC code? How do you define the features as operations? and define the machining processes required. Any help would be greatly appreciated. the target machine is Haas VF2 and the material is .050 copper sheet that is mounted to a fixture block. |
| If it is a solid you need to convert it into surfaces, then convert the surfaces into lines and arcs using "create, curves all edges" unless your programming 3d . |
| a bit late, didnt notice the date |
| Tags |
| help a newbie, iges, mastercamx, program |
| Importing .IGES file into SW 2007 | 2_jammer | Solidworks | 3 | 12-29-2007 12:23 AM |
| iges file Les Paul top | Dconlee | Musical Instrument Design & Construction | 8 | 12-28-2007 09:56 PM |
| IGES file? | machining22 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 11-12-2007 06:29 PM |
| Analysing an iges file | Julian M | Mastercam | 15 | 12-09-2006 04:16 PM |
| working w/ iges file | tom@wave-l | Mastercam | 6 | 07-13-2005 01:57 PM |
