Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-29-2008, 10:18 PM
jeffsnure is on a distinguished road
machinemate tool radius offset ???
i'm using a machinemate MM1 controller in our K&T horizontal mill and i'm working to learn the use of the tool radius offset setting ( or the d parameter ). the thing that has me confused is the two part parameter, ie....... d01 +0000.0000 +0000.0000
does one specify x and the other y if g17 is xy plane and so on if other?????
thanks
Tags
d01, g41, machinemate, offset, path compensation
Radius Offset and Length Offset jim_stoll Dolphin CADCAM 13 10-14-2010 08:47 PM
Changing tool diameter in the tool offset screen Vern Smith Haas Mills 21 09-24-2008 10:54 AM
Need Help!- Tool nose radius offset question JV58 Mori lathes 9 06-04-2008 11:39 PM
G42 Tool nose radius. al-108 Okuma 5 03-02-2008 02:39 AM
Tool Radius Compensation davidmb General CAM Discussion 5 07-29-2005 10:16 AM
