Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-25-2008, 03:52 PM
Al_The_Man's Avatar
Drill Macro by Hardinge
Going through some files, I though I would repost this in case someone can make use of it.
Old 05-03-2008, 09:36 AM
g-codeguy is on a distinguished road
Hi Al. Hardinge has a new and improved drilling cycle. I'm sure you will like it better than the 9165 program. Old program required you to modify the H to get the desired depth of 1st pass. New one allows you to directly specify it. Also allows for parts that already have a counter bore or have already been drilled part way with a larger drill, or were roughed in another operation, etc.
G65P9136K-1.75B.02F.007W.65C.25A.2Z-.375
Difference is W is the amount of the 1st peck. Z is the starting point for drilling.
I've mentioned this program on a couple threads. Only had one person respond. He never replied after I gave the subprogram to him, so I don't know if he liked it or if he could even use it on his control.
I use this subprogram on all our Fanuc controlled lathes. Would you be interested in it?
Drill Macro problem toolmanwaz CamSoft Products 5 04-01-2008 11:47 AM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 02:32 PM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-09-2007 12:41 AM
fanuc drill mate / robo drill post for enroute? goodplastics Post Processor Files 0 07-19-2007 06:49 PM
Noob Drill Grid Pattern Macro Question KOzOK Fadal 8 01-08-2007 10:11 AM
