| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| mach 3 IM HAVING A PROBLEM WITH SPEED OF CUTTING ON MY CNC. I USING CABINETPARTSPRO PROGRAM TO GENERATE G CODE AND MACH 3 TO RUN MY MACHINE. BUT ITS JUST TO SLOW.WHEN MACHINE STARTS TO RUN I BUST FEED RATE TO 300% AND ITS STILL TO SLOW. IM WONDERING IF THERE IS ANYONE WHO CAN HALP ME SINCE IM NEW TO ALL THIS. THANKS |
| http://www.machsupport.com/forum/ind...ic,6121.0.html try this post in Machsupport...it may help you...basically you might need to edit your Gcode feedrate (f15 for example to f60) just for starters...higher if you machine will take it... hard to determine not knowing what machine setup you have hope i was able to help Bob |
| You should be able to set the feedrates in CabinetParts Pro somewhere.
| Confused: Mach Turn, Mach Mill, Mach 2/3 ? | CanSir | Mach Software (ArtSoft software) | 5 | 02-16-2007 05:41 AM |
| K2 With Mach III? | GuitarEng | Commercial CNC Wood Routers | 5 | 11-10-2006 08:18 PM |
| Mach 3 no spindle - but OK in Mach 2 | zcases | Mach Software (ArtSoft software) | 9 | 07-31-2006 08:38 AM |
| Moving to mach 3 need exact mach 2 screen | carlnpa | Mach Software (ArtSoft software) | 2 | 12-11-2005 04:00 PM |
| will mach 2 or mach 3 work for 4 axis cnc? | Runner4404spd | Mach Mill | 3 | 10-05-2005 12:44 PM |
