| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
I have an old Sherline CNC mill with a stepper motor controller box made by "Backtrack Manufacturing". I don't have the software that came with the controller to run Gcode. The controller box has 4 inputs from the parallel port that drive 4 fets to the stepper motor coils for each axis. The control box will drive 3-axis. What I need is software like Mach3 that will take gcode and control the stepper control box. From what I've read Mach3 will send out a direction and step signal to each axis for control and will not work with this control box. Does anyone know of software that will perform the function I'm looking for? Or maybe the software that came with the control box? I have borrowed this setup from a friend with the intention of getting my feet wet in the world of maching and CNC maching so any help would be greatly appreciated. Thanks. |
| Hi, The only info I can find on backtrack manufacturing is a few dead links and references to sherline. http://www.btcnc.com/ It doesn't work, maybe its temporary? Have you thought about a new controller. HobbyCNC sells a nice controller for <100 dollars. New software can cost more. Chuck
__________________ http://chuckscnc.blogspot.com/ |
| Sorry for the double post but here's an even cheaper solution for the more adventurous sort. http://www.doctronics.co.uk/4017.htm Decade counters can output in sequence from 0 to 4 from a step signal. I don't think it can count backwards for the direction signal tho. Synchronous counters can, I'll see if I can find one.
| It is open source, so maybe. But I have no experience with it. This might be what your looking for in emc http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Stepgen it only supports 8 outputs though. You need 12?
Thanks! |
| The machine is now controlled by EMC2. I'm now able to jog the x, y, and z axis. I started with the "stepper-xyza" configuration and modified the "standard_pinout.hal" and "stepper_xyza.hal". I set "loadrt stepgen step_type=6,6,6" and deleted the 4th axis. One thing the documentation is incorrect about is when assigning pins you use "phase-A" not "PhaseA". For example in "linkps stepgen.0.phase-A XA". I still have some more configuration to do for limits and travel but that's general setup stuff. |
| sherline cnc advice | nantz | Benchtop Machines | 0 | 02-28-2007 09:34 PM |
| sherline or bigger? | landongw | Mini Lathe | 1 | 02-19-2007 04:15 PM |
| Looking For The Best Sherline Cnc Kit | BUD B | DeskCNC Controller Board | 1 | 12-08-2005 10:04 AM |
| Sherline spindles | rc-cellar | Benchtop Machines | 4 | 10-17-2005 03:16 PM |
| software for 4 axis zylotex/sherline setup | shindin | Xylotex | 2 | 10-15-2004 05:58 PM |
