Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-14-2008, 08:03 AM
ARCOBALENO is on a distinguished road
2D Milling Engraving
Hi, I have a Roland EGX-300 CNC Desktop engraver which I bought purposely to make Aluminium and Brass metal printing blocks for letterpress and Hotfoil printing. The difficulty that I am experiencing is that with the software that came with the machine I find that it is a little bit limited. I am referring to the 3D engrave. I have purchase Carbide Tipped cutters of 20 degree angle so that when I engrave the image I will not loose from the printing area face when I have to go down to about .9mm deep and where it needs to be engraved both on the inside and out side of graphic. Example a circle, or let say Initial letter R.
Cutting a 2D image with a 3D software seems that the engraver starts working itself from depth upwards instead of the opposite. I have only tried to engrave using soft plastic material to experiment and understand better how things work first and to avoid breaking my tools and the engraver.
Is there anyone who have any suggestions about this problem?
Thank you in advance.
Need Engraving Help G47 BigBoBo G-Code Programing 6 07-04-2008 04:37 AM
Fun With Engraving... 10bulls CamBam 8 03-24-2008 10:18 PM
Engraving innovator Bridgeport and Hardinge Mills 1 01-10-2008 06:17 PM
PCB Milling/Engraving forum gtrdude Suggestions for the CNCzone.com site. 1 04-11-2006 01:40 AM
Newbie to CNC Engraving / Milling machines new help building from scratch tera_bit DIY-CNC Router Table Machines 3 03-23-2006 08:39 PM
