Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-12-2008, 06:29 AM
modulus is on a distinguished road
PMC PARAMETER MORI DL20MC LATHE
On friday I had the dreaded parity error message on screen after switching the machine on. Ended up clearing the memory and inputting the parameters again.
These are all in now and the machine is zero returning, spindle running etc, however I have a problem inputting some of the pmc parameters (data). some of the values will not go in. I just get 'invalid input' It seems the data I am trying to put in is too high a value for the field.
eg DOOO6 Value should be, (according to my backup) 12144 however it won't accept any value above 127. Any value above this causes 'invalid input'
Anyone know of this problem. There are many other of the data values like this.
Strangely the machine will run a program in this state. though I only tried rotating the turret and starting the spindle.
Control is a FANUC 16TT badged as MORI MF-D6
Any help would be greatfully received
Andy
PS I inputted the password protected parameters D200 - D209
Fanuc SYSTEM 5/Mori lathe set-up HapSmo19 Fanuc 6 01-21-2009 03:48 AM
Parameter to change for barrier control on a T2 lathe nervis1 Mazak, Mitsubishi, Mazatrol 3 08-28-2008 04:16 AM
nam sun lathe/mori seiki knock off jheyliger General Metal Working Machines 1 04-27-2008 02:42 PM
Way lube issue on Mori lathe bob1112 General Metal Working Machines 2 03-12-2008 01:38 AM
Parameter question for MSX-501 on Mori mill tminnig Fanuc 0 10-02-2007 02:57 PM
