Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-11-2008, 03:15 PM
gj83 is on a distinguished road
help with macros
I need to determine for sure whether or not my machines are capable of using macros.
I tried putting the statement #501=#501+1 into all of the controls and it worked on some and not on others. I know this would be how a fanuc control would read in a macro since I've done the most programming on a fanuc but I'm not sure about the others. Should this statement work in most controls?
The machines I have (and thier controls):
Horizontal MCs:
OKK KCH-500 (OKK Neomatic)
Mazak Mazatech H-400 (Mazatrol M32)
Cincinati 10HCR (Vickers Acramatic 2100)
Enshu JE80S (Fanuc Series 18i-MB)
Vertical MCs:
Cincinati Lancer (Cincinati Milacron Acramatic 2100)
Cincinati Arrow (Cincinati Milacron Acramatic 2100)
Horizontal Lathes:
OKUMA LB15C (OSP5020L)
OKUMA LB15U (OSP5020L)
OKUMA Cadet (OSP700L)
OKUMA L470M (OSP-P200L)
Gantry Style MC:
Okuma MCM-B (Okuma OSP7000M)
Thanks for any help you can provide!
Old 04-11-2008, 08:38 PM
CNCRim's Avatar
well simple test just type in #100 in MDI and start, if you don't get an alarm then machine has macro option. However double check with your manual, because some machine has difference format. For example, Fadel is v1=xxx and for Seimen @K1=xx so check your manual for further detail.
I havn't use Okuma before, so I don't know.......
Old 04-11-2008, 09:42 PM
broby's Avatar
broby is on a distinguished road
All Okuma machines have what is called "User task 1"
This gives you basic "macro" style programming abilities but can be a little bit restrictive at times.
Most of the Okuma machines I have worked with have had "User Task 2" as a added option, thus giving access to more features.
I can not remember what the differences are off the top of my head, but depending on what it is you wish to do I do not think it should be too much of a problem. If I remember I will find out for you.
Okuma does not use the #100 type of construct for its variables, it uses "common varaibles" by way of V1..V32 for variable 1 through to V32 (this being on the lathes that we have) and VC1..VC200 on the mills. One older mill only has VC1..VC128 but that is more than enough anyway.
You can also use user created variable names within your program if you do not need to "keep" your variables after the program has run.
User defined names can be no longer than 4 characters long and mus start with an Alpha character not a number. i.e. TEST is fine but 1TXT is not.
There is a few other things with naming variables that also put a stop to the system real quick, like starting variables with the letter "O", there are others but I do not recall the list at home here.
Passing variables into a sub routine is very easy, returning results is not.
If I need to return a value I usually use a common variable to do so.
User variable names are only "visible" within the program that is using it at the time same as for subroutines, i.e. the variable SIZE in the main program can be different to the the variable "SIZE" in a subroutine. Thus you can pass a value into a sub program like
N100 SIZE=100.25 (CREATE AND SET A VARIABLE CALLED SIZE)
N102 CALL OMILL SIZE=SIZE and the sub program variable is passed the information from the calling program.
Mind you, you can also call the sub like this:
N100 CALL OMILL SIZE=100.25 and this would be the same.
Use of the Common Variables is simple.
Assumming you have a number set in the parameter page for the common variables on Variable 1 then you can position the machine thus:
G0 X=VC1 or G0 X=V1 (depending on your machine)
All the usuall maths functions are available within the Okuma User Task language, but I seem to recall that Trig functions are only available in User Task 2. Easy to test tho... in MDI type in VC1=SIN[30] press write and cycle start and see what comes up in VC1 if the machine does not alarm out you are in luck... otherwise?
Hope this helps
Brian.
Need Help!- macros bob@apc Mazak, Mitsubishi, Mazatrol 2 02-04-2008 12:42 PM
Help with macros afterburn25 Haas Mills 4 04-09-2007 09:19 AM
Macros cncfreak General CAM Discussion 24 05-06-2005 06:04 PM
macros toyoda General CAM Discussion 0 05-30-2004 05:56 AM
Macros MachineSMM General CAM Discussion 2 06-20-2003 01:41 PM
