Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-06-2008, 12:03 AM
ballchain is on a distinguished road
YASNAC LX-3 on METHODS Slant 50 Rapid Traverse issue!
I'm not sure if it's a simple software problem or a factory setting, but the rapid traverse is WAY TOO SLOW when a program is running and G00 is invoked.
When jogging in rapid, everything flies around at a good speed, but when a program is running (even a simple test to move it around) it's the slowest thing ever, really hurting cut times.
I've been digging through the manuals (which have you jump around between to get an answer) and can only come up with the following....
Under PARAMETERS, #6219 needs to be set to 1 (currently at 0) in order to change the Rapid Traverse rates parameters.
In order to change #6219 to 1, you have to move a switch on the mainboard to 1 from 0. Either I'm doing something wrong, or this isn't the correct step.
I believe that after setting #6219 to 1, you should be able to cursor to, and change the #6280 and #6281 parameters (Z and X rapid traverse settings)
Problem is that I can't even get #6219 to change!
I hope I'm doing this wrong and there's some simple fix, which is why I'm reaching out to you all. Any information and advice would be greatly appreciated!
Thanks in advance.
Old 04-19-2008, 10:11 AM
This issue has been solved!
rapid traverse how to calcute moter size etc eloid Linear and Rotary Motion 1 02-27-2007 06:13 PM
Please Help With Best Practise Methods Joey Fanuc 12 01-09-2007 01:42 PM
Fanuc Oi rapid traverse problem longcut Fanuc 2 11-22-2006 04:03 PM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 04:19 PM
Rapid Traverse Too Fast gopackgo Mach Software (ArtSoft software) 6 11-25-2004 12:50 AM
