Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
  #13   Ban this user!
Old 04-13-2008, 12:45 PM
elexolman is on a distinguished road
I really, even though it is using USB hardware, would not refer to it as USB, since the device uses a virtual com port driver to make it as if the USB port was a COM port, making it easier to program (and simpler if I use a machine other than my own, and COM ports are going away on many comps)... and it looks like the .DXF thing would work for me, but I still would like to be able to use a 3D model... maybe I'll save that though for an update : )
right now I am looking at mach3, and it seems that there is a dev version, which might help me out a LOT!...
Old 04-13-2008, 01:05 PM
ger21's Avatar
The development version of Mach3 is just the most recent release, it won't give you any code to look at. You might want to look at the source code for EMC. Part of Mach3 was based on the EMC code. Be aware that Mach3 is the result of one person working 8-16 hours a day, 7 days a week, for almost 5 years to get where it is today.
  #15   Ban this user!
Old 04-13-2008, 01:53 PM
I meant the SDK that appears to be available...
[ADDITION]: just thought I might put this out there, thanks to the Arduino I recently got, I also can now make the machine not need a computer (assuming the raw directions for a set, but re programmable, output are made first)...
  #16   Ban this user!
Old 04-13-2008, 01:57 PM
chazmtu is on a distinguished road
My mistake. Looks like Switcher and Ger21 Know a whole lot more than me about that, no surprise there.
http://chuckscnc.blogspot.com/
Mach3 Mill.... Motors not turning. junior85 Mach Mill 3 05-29-2007 01:45 AM
Cut Directions thebiglad EdgeCam 6 07-29-2006 09:31 AM
Access to Fanuc motors/amps for BP Boss, help me choose model jderou Bridgeport and Hardinge Mills 1 07-16-2006 11:36 AM
Manual turning of stepper motors Pat Stepper Motors and Drives 1 08-08-2005 03:04 PM
It's getting there....motors are turning johnt CNC Plasma and Waterjet Machines 1 03-27-2005 05:34 PM
