| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
#15
What about this; % O0001 G0 G91 G28 Z0 G28 X0 Y0 G92 X175. Y55. Z307. G0 G90 X0 Y0 S1000 M3 G43 H2 Z2. M8 Z-2. G1 G41 H22 (set your "H" value equal to 1/2 tool diameter)X0 Y2. F??. G1 (some machines respond better to repeated G1's) Y-50. G1 X-100. G1 Y50. G1 X2. G1 G40 X20. F??. G0 Z20. M9 G91 G28 Z0 Y0 M30 % I personally do not have to repeat the G1s on either of the Mills I run, both Kitamuras. One has Fanuc, the other Yasnac controller. Also if you wanted fillet radii corners add your G2 move between each of the G1 lines. Remember to account for the radius when doing those G1 moves and leave enough distance to make your arc before the next G1. Also I noticed in your example you went G0 before comping off G40. Did this not cause an error? If I must move up (Z) before moving out (X,Y) I have to leave G41 on and make a G1 Z++ then comp off G40. Hoped this helped. |
| machine problem or software problem? | bcnc | Syil Products | 8 | 10-26-2009 09:51 AM |
| Cuttercomp? | jb_swampfox | Torchmate | 2 | 06-20-2007 03:15 PM |
