Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 03-11-2008, 02:27 PM
rajiv.tctech is on a distinguished road
Question Help!! Using Formulae to turn ovals with Mach3
I need to turn an oval object where elliptical path around the object axis can be defined by a standard equation describing an ellipse. I can see Mach3 should be able to do this by using its formula function... only I don't know how to go about it.
How about guiding the lathe x-axis along a sinusoidal or cosine path around the turning axis? I think there is a huge potential here...
Can anyone help?
Rajiv
Old 03-11-2008, 05:27 PM
Andre' B is on a distinguished road
Here is a post I did a short while ago.
http://www.cnczone.com/forums/showpo...22&postcount=4
And playing with it a bit more, I added some Sin wave noise to the ellipse.
Code:
G0X0Y0
#100=1.0(X RADIUS)
#101=2.0(Y RADIUS)
#102=0.25(ANGLE STEP)
#104=30.0(ROTATE PATTERN)
#106=60.0(MULTIPLIER FOR NOISE FREQ)
#107=0.3(MULTIPLIER FOR NOISE AMP)
#103=-1(COUNTER)
G68X0Y0R#104
#105=#107*SIN[#106*#103]
G1G41X[[#100+#105]*COS[#103]] Y[[#101+#105]*SIN[#103]] D1 F10.0
WHILE [#103 LE 360] DO1
G1X[[#100+#105]*COS[#103]] Y[[#101+#105]*SIN[#103]] F10.0
#103=#103+#102
END1
G1G40X0Y0
G69
Here is a good book for learning this type of programming.
Not all of it will apply to controls like Mach3 but still a good referance.
http://books.google.com/books?id=YKv...sec=frontcover
Name:	Ellipse with Sin wave noise.jpg‎
Old 03-11-2008, 10:23 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Why not post on the Mach 3 site? www.artofcnc.ca and goto the general discussion forum, those guys are VERY helpfull. Good luck!
Tags
mach3 formula
New FeatureCam Mill (3axis) and Turn Posts for Mach3 chris59 Screen Layouts, Post Processors & Misc 1 04-05-2008 02:43 AM
Set Home on Mach3 Turn scot1972 Mach Lathe 1 03-12-2008 01:46 AM
Turn off the system beep in Mach3? fatal-exception Mach Mill 0 09-19-2007 02:20 PM
G-code manual for Mach3 turn? Green0 Mach Lathe 4 06-25-2007 07:57 PM
Need help with a subroutine formulae... Darc G-Code Programing 2 01-09-2006 05:05 PM
