| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
I have a series 1 Bridgeport mill that I wanted to retrofit with a CNC kit, But before I take the plunge. I wanted to know and learn first the software process. I already know some software programs like Corel, Illustrator, and AutoCad. From there I do not know what s next. I'am a custom knifemaker and I'll be using a CNC to make knife blanks and parts. Any help would be greatly appreciated ![]() Also which among this 3 programs ( Corel, Illustrator, and AutoCad ) I already know would be the best jumpstart for CNC programing |
| Depends on if you'll be doing need 2.5D or 3D work. For 2.5D you draw the part in anything that can export a .dxf file. Not sure about Illustrator, but both AutoCAD and Corel will work. You then bring the .dxf file into a CAM package to create the g-code. A good inexpensive one is SheetCAM. The CAM program will then do offsets if desired, pocketing and drilling and create toolpaths and export a g-code file. Then load the g-code file into your machine control software and start cutting. I've written an AutoCAD macro that will create g-code for any polylines in a drawing. Works with AutoCAD 2002 and newer. http://home.comcast.net/~cncwoodwork.../AC2GCv039.zip For 3D work, the process is similar. You create a 3D model in a CAD or modelling package, export the model and bring it into a 3D CAM program, which will create toolpaths and export the g-code.
| Software Process | Ang_Panday | Bridgeport and Hardinge Mills | 0 | 02-13-2008 05:31 PM |
| design and machining process | project5k | Mechanical Calculations/Engineering Design | 17 | 08-07-2007 09:16 AM |
| In the process | Smitty911 | Dolphin CADCAM | 5 | 05-10-2007 12:34 AM |
| Tig Process ?? | millman52 | Welding, Brazing, Soldering, Sealing | 46 | 04-30-2007 01:41 PM |
| What kind of process controls does MC have? | HuFlungDung | Mastercam | 3 | 05-28-2003 10:31 PM |
