Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 02-10-2008, 01:39 PM
mltw is on a distinguished road
program transfer with a acramatic 850sx
please help....cin. sabre with acramatic 850sx when transfering a program using rs232 dataline I can only get the program to go from the control to the pc. when I try to go from the pc to the control I get a 00195 device parity error and I have tried every combination and settings and nothing seems to work. I am using cadem nclite and I have it set up like they show and it says its proven to work but its not for me.
baud rate 2400
parity n
data bits 8
stop bits 1
handshak hardware
cable connection is null modem pin configuration
thanks
john
mltw machine
Old 03-13-2008, 09:04 PM
debco99 is on a distinguished road
I was in Texas on service (850sx) and had exactly the same problem, only with Mastercam.I have a copy of a file transfer program that works if you want it.
I spent at least a full day on this problem and finally gave up.
If you want it I will be glad to email it to you. It saved me.
Good Luck
Old 03-13-2008, 09:19 PM
beege's Avatar
beege is on a distinguished road
Delete
Old 03-13-2008, 09:21 PM
beege's Avatar
If I remember (10 yrs ago) either the machine used 8 data bits while the PC had 7, or the other way around. Try them mismatched like that.
Old 03-13-2008, 09:35 PM
SGARCIAM is on a distinguished road
Try this
COMP 4800,7,E,1
Machine 4800,8,N,1
Dataline
Old 04-27-2009, 06:08 PM
ultpd is on a distinguished road
Same Problem Here;
Hello All;
I am new to this site and so far see its great. I have been in the CNC programming/operating industry for the last 12 years and worked on many stiles of controlles but I must say I met one that drives me up the wall. We just bought a used Sabre 1000 and while waiting for the manual to come in that we purchased off the net i am trying to perform some simple tasks and somewhat got the control and machine figgured out but having the same problem as john with the upload of the program. Using a dos based software download is great but get a error on upload. any suggestions would be appreciated.
Thank you;
Peter.
Old 04-28-2009, 02:52 PM
This is what I use for the pc side
baud=2400
Parity=none
Stop Bits=2
On the control
Stop Bits=1
use a standard null modem cable, I use the same one I use on Fanuc
If you want a nice transfer program get in touch and I will send the one I use
Old 04-28-2009, 07:22 PM
See I tried all different settings today again and its killing me. I got the machine used and have several different settings in the machine but the machine just sits there till it times out. Machine to comp is no problem so for now I just had to do the dirty work of manually inputting the data. On the up side i am getting pretty creative with sub programs. If you would not mind sending me a copy of your program that would be great. my email is ultpd@hotmail.com.
Thanks in advance.
I am going to give it another go tomorrow because knowing me I will not be able to sleep at night till i get this.
Acramatic 850SX parts markp General Metal Working Machines 2 08-28-2009 08:45 AM
Acramatic 850sx Cutter comp + MCAM X2 foxsquirrel General Metal Working Machines 0 01-23-2008 08:50 PM
acramatic 850sx controls? any experts? stanglou General CNC (Mill and Lathe) Control Software (NC) 5 12-28-2006 10:26 PM
Acramatic 850sx video board coalstove General Metal Working Machines 0 11-08-2006 08:57 AM
acramatic 850sx KLH Machine Problems, Solutions , Wireless DNC, serial port 2 07-18-2006 10:29 AM
