Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 01-23-2008, 02:27 AM
mostafabagheri is on a distinguished road
mitsubishi meldos 310 - dnc problem
any body help me with mitsubishi meldas 310 mill
when i transfer a program (this program creat by power mill & send to the machine by cimco edit ) to the memory & execute this program from memory i dont have any problem & the xyz axis run very good &smooth & countiuse but when i want to run this program from pc by direct connection (dnc mode) yhe xyz axis dont run smooth & i have a step-by-step move (like this -----) two program are same and all setting in cnc are also same
Old 01-24-2008, 08:28 PM
dcoupar's Avatar
What baud rate are you communicating at? What feedrate are you programming? How long are the line segments you are interpolating? Sounds like the baud rate is too low for the feedrate you have programmed.
Old 01-31-2008, 09:30 AM
buadrate
feedrate is 2000mm)min and baudrate is 9600 but in meldos catalog say the max baudrate is 1240
Old 01-31-2008, 10:31 AM
dcoupar's Avatar
I'm not familiar with the Meldas 310, but I'm pretty sure there is no such baud rate. 110,300,600,1200,2400,4800,9600 are all pretty standard, but 1240?
I'm also not familiar with Cimco Edit's DNC settings, but check to see if there's either "Character Send Delay", or "Line Send Delay" or anything like that that could be slowing the transmission down.
Old 02-01-2008, 05:17 AM
dnc
sory for this typing ignore . 1200 is true . and i can find these parameters in cimco :
delay befor each line
handshake timeout
breack after receiving character
are these useful for our problem ? and do you have any good suggest for adjust this parameter ?
do you have any good software for dnc ?
and say again tanke you for your help
Old 02-01-2008, 05:26 AM
dnc
handshake timeout
Old 02-01-2008, 05:45 AM
handshake timeout
Old 02-01-2008, 08:52 AM
dcoupar's Avatar
Delay Before Each Line sounds like the one. If it's not already, try setting that to 0.
I'm confused... is your baud rate set to 1200 or 9600? If it's 1200, bump it up to 4800 or 9600. If it's 9600, bump it up to 19200. If your cable is good, and the handshaking is working properly, you shouldn't get overflows.
Old 02-01-2008, 09:05 AM
SORCHEROR is on a distinguished road
the 310 wont handle a rate higher than 9600,what is your computer?older one,sometimes this causes a dnc problem
Old 02-02-2008, 07:32 AM
dnc
i have a same problem in richmond machine , in richmond my baudrate is 9600 & in meldos machine 1200 , and i use new labtop for dnc
  #11   Ban this user!
Old 02-02-2008, 07:42 AM
hutch07 is on a distinguished road
handshake timeout
Go to your Parameters - in/out screen and see what the handshake time out setting is. I know Mitsubishi lets you set this. Bump it up to 200 seconds to see if this helps. check out www.meau.com
  #12   Ban this user!
Old 02-02-2008, 07:47 AM
My problem also.
I am also looking for a good up-load/download program. I can not communicate with the Mitsubishi Meldas L3. I have gotten a few characters using some stuff but nothing usefull,
Dnc problem for Mitsubishi Meldas 520AM koeitool General CNC (Mill and Lathe) Control Software (NC) 4 05-04-2010 12:40 PM
Dnc problem for Mitsubishi Meldas 520AM koeitool Mazak, Mitsubishi, Mazatrol 5 10-18-2007 11:48 PM
Mitsubishi DWC-110H A Wire EDM Floppy Problem tjurek Machine Problems, Solutions , Wireless DNC, serial port 5 10-11-2007 07:08 AM
HELP! Mitsubishi cnc hobb problem Jay Rad General Metal Working Machines 0 03-22-2007 01:08 AM
Mitsubishi spindle problem wcopley Mazak, Mitsubishi, Mazatrol 16 11-08-2006 07:06 AM
