Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 12-25-2007, 02:48 PM
chester1957 is on a distinguished road
First cnc project
I found this forum while researching a winter project.
I have been interested in the hardware side of cnc, having been involved with running and programming cnc for quite awhile.
I have basic knowledge of the components required and the type of system I will build.
For the first project I am going to retrofit my unimat 3 lathe with 3 axis control, the third being a motor driven tailstock.
I have two pc power supplies a 90 watt max and a 200 watt.
They are 5V10A,3.3V6A,12V1.5A5VSB1.4A and 5V20A,12V7.5A,12V.5A,5V.5A respectively.
Being a small machine cheap steppers to start would suffice and the above power would be OK. My problem is the drivers as they seem to be the expensive components in this system.
I want to reuse the drives along with upgrading power supply and stepper motors on a planned benchtop mill.
The budget for this first phase is two to three hundred dollars, the question is can drivers be had for this plan of action?
My little project Pyrotechnical Plasma, EDM and other similar machine Project Log 37 08-31-2008 04:11 PM
My cnc project llilrex DIY-CNC Router Table Machines 1 11-05-2007 07:17 PM
Need help on a project ClemsonGirl General CAM Discussion 6 01-24-2006 03:12 PM
First project Xterrian Coding 2 10-01-2005 01:24 AM
Project: NCR-OAB Nonoriginal CNC Wood Router Project Log 0 02-18-2005 02:13 AM
