Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 11-21-2007, 12:23 PM
Crashmaster's Avatar
Crashmaster is on a distinguished road
G71 not working... Am I an idiot?
OK, so the post title kind of sets me up, oh well. I am attempting to use G71 on a controller I have never used it on before. Its a Fanuc 10T, and my program looks more or less like this:
G71P10Q20U.060W.005D1250S600F.012
N10 G0 X.8
S800
F1X1.5Z1.75F.006
Z1.
X1.75Z.625
G2X2.5Z.25I.375
Z-.15
X2.875
N20
The problem is that the control reads the G71 line and skips directly to N20. So now I ask the question.... Am I an idiot?
Old 11-21-2007, 12:35 PM
You have a line that reads:
F1X1.5Z1.75F.006
What is the F1 before the X doing?
I program for Haas not Fanuc and with that F1 removed I think your code would run fine on a Haas. However, I seem to remember seeing that Fanuc needs two lines to set up some of the canned cycles; you would put the P and Q on the first line then the other things on the next line down.
G71P10Q20
G71U.060W.005D1250S600F.012
etc
Old 11-21-2007, 01:28 PM
wisp's Avatar
wisp is on a distinguished road
here is an example from one of my program for a fanuc controlled Daewoo lathe.
N5G99(NS2602-ROUGH FACE AND OD.)
N10G0T0101
N15G50S1200M41
N20G96S275M4
N25G0X8.15Z.01M8
N30G1X4.8F.01
N35G0X8.Z.1
N40G71U.1R.05 (U=cutting depth, R= pullaway distance after each cut)
N45G71P50Q75U.022W.005F.012 (on 2nd line U is stock for finishing on diameters, W is stock left on shoulders in Z axis)
N50G0X5.6658
N55G1Z.05F.012
N60G1X6.9822Z-1.09F.006
N65X7.4196
N70X7.81Z-1.1423
N75Z-2.63
N80G0X8.375Z.5M9
N85X12.Z12.
N90M01
(1 3/4 BB. CARBIDE-NS 1405 ROUGH BORE)
N95G0T0606
N100G50S1200M42
N105G96S350M4
N110G0X5.375Z.5
N115X4.9Z.1M8
N120G71U.125R.05
N125G71P130Q145U-.022W0.F.012
N130G0X5.4529
N135G1Z.05F.012
N140X5.2565Z-.0482F.006
N145Z-2.63
N150G0Z.5M9
N155X12.Z10.
hope that helps,
cheers,
Michael
www.cncfusion.com CNC kits for Sieg mills and lathes
Old 11-21-2007, 02:35 PM
That F1 is a typo, oops. It should be a G1. Wisp, thanks for the info. I am actually off of work until next Monday, so I can't try until then.
Old 11-21-2007, 05:26 PM
dcoupar's Avatar
Try this one:
N10 G0 X.8
S800
G1X1.5Z1.75F.006 (CHANGED F1 TO G1)
Z1.
X1.75Z.625
G2X2.5Z.25I.375
G1Z-.15 (ADDED G1 HERE)
N20X2.875 (MOVED N20 HERE)
Simple CNC Software For An Idiot jfk0816 General CNC (Mill and Lathe) Control Software (NC) 2 09-24-2007 07:42 AM
OneCNC Mill demo - I'm an idiot Matt@RFR OneCNC 19 08-16-2007 09:13 PM
THC 300 not working? Redline CNC Plasma and Waterjet Machines 3 12-30-2006 08:40 PM
Electronic idiot... motors twitching fool Xylotex 4 01-31-2006 11:57 AM
complete idiot help here please soarnut G-Code Programing 0 01-04-2006 09:07 AM
