Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-22-2007, 12:41 AM
MrWild is on a distinguished road
Crusader-M Duart failed but.....
It works. Out of curiosity I did the diagnosticts on my WORKING Crusader-M. It does everything it is supposed to. It eats uploaded code and makes the moves while turning on and off the spndle and coolant when needed. All tests pass except for the DUART, and now I'm wondering about the guys with balky Crusader-Ms and their DUART test failures. I'm thinking the DUART failure in diagnosticts might not have been the problem with their controls. Oh well, I've been slowly putting together a up to date control and when this one bites the dust I'll just swap it out. Maybe sooner if everything comes together finally.
Old 10-23-2007, 12:24 PM
rgammage is on a distinguished road
Duart Failure
Hello There
It sounds to me as if the system is trying to do a communication test and is expecting to see a 'loop-back' plug where you currently have your computer plugged in!
If it aint broke don't fixit ....
Regards
Richard
Old 08-15-2008, 02:10 AM
JPW JPW is offline
JPW is on a distinguished road
I also have an M. There is no uart in that control. Mine also says that it failed.
Keep on Krankin
Old 08-15-2008, 06:16 AM
Gold Member
HillBilly is on a distinguished road
I talked to a tech at Anilam about this. They basically said what Richard said. It will fail unless you had a test plug connected.
Darek
X axis transistor failed...AGAIN Mr. Technical Bridgeport and Hardinge Mills 18 08-21-2007 06:16 PM
Anilam Crusader II - Crusader 2 Training DVDs Mike Mattera Product Announcements & Manufacturer News 2 07-08-2007 09:31 PM
Boolean difference failed chetosmachine Rhino 3D 8 06-12-2007 05:24 PM
Failed transformers? Jetlag General Electronics Discussion 2 09-09-2005 02:50 PM
V2XT - machine check failed zcases Bridgeport and Hardinge Mills 3 06-07-2005 02:16 PM
