Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-18-2007, 11:15 AM
koeitool is on a distinguished road
Dnc problem for Mitsubishi Meldas 520AM
Hi,ALL:
Our CNC machine controller is Mitsubishi Meldas 520am(very old), PC operation system is Windows XP. RS232 connection: CNC Machine---25pin---25 pin---converter---9pin---PC. My RS232 line is connected like the following:
PC CNC
1---------------------- 1
3 ---------------------- 2
2 ---------------------- 3
7 ---------------------- 7
6-8-20 6-8-20
4-5 4-5
I have no problem to send very very small NC programs to CNC machine using ConnectCNC.( Using Xon/Xoff flow control, baud rate 4800, data bits:7, stop bits:2, parity: even). Since the memory at machine side is very small (less than 100k), I try to use DNC, but don't succeed, with error "P460 TAPE I/O ERROR". ConnectCNC does not seem to care about whether the CNC machine is ready for receiving or not, and it just sends the NC program after the SEND button is pressed. It never waits for a Xon singal.
The funning thing is that the machine can't receive a small NC program when I use " Wait for Xon" function in other software such as Cimco edit (same settings as ConnectCNC on both PC and machine sides).
so my stupid questions are:
Is the Meldas 520 using the same port for data receiving and sending?(There is only one port on machine).
Which handshake is better for this old machine( Xon/Xoff or hardware handshake or no handshake)?
Any suggestion will be appreciated.
Thanks in advance.
Old 10-23-2007, 01:34 AM
m.amir is on a distinguished road
you can try, " CncSimulator Ver 4,44f (2,7 Mb) "can download free version . http://www.cncsimulator.com
25 pin------------------9pin
1+7---------------------- 5
3---------------------- 3
2 ---------------------- 2
4---------------------- 8
5-----------------------7
6-8-20 jumper 1-4-6
Using Xon/Xoff flow control, baud rate 4800,data bits:7, stop bits:2, parity: even
Old 10-23-2007, 10:01 AM
dcoupar's Avatar
Are you using a laptop with a USB to Serial adapter? I've had problems with these trying to use XON/XOFF handshaking.
Old 10-24-2007, 04:08 AM
i am not using a laptop. i used standerd pc with 9 pin Serial port direct to machine side 25 pin Serial port.
Old 05-04-2010, 01:40 PM
VOLFAN is on a distinguished road
This a different topic but I am having trouble rigid tapping with this same controller. I get a different alarm with everything different that I try. Could someone please post a sample tapping program so I can see what I am doing wrong.
Thanks in advance
Dnc problem for Mitsubishi Meldas 520AM koeitool Mazak, Mitsubishi, Mazatrol 5 10-19-2007 12:48 AM
Mitsubishi Meldas 60S BKCOM General CNC (Mill and Lathe) Control Software (NC) 0 08-29-2007 03:07 AM
mitsubishi meldas 50l switching to japanese BAD DOG General Metal Working Machines 2 08-20-2007 10:33 AM
ask for help about connecting pc to mitsubishi meldas 50s samhai Mazak, Mitsubishi, Mazatrol 1 04-16-2007 04:39 PM
Mitsubishi Meldas 300-V firestaromega Computers and Networking 3 05-24-2006 09:37 PM
