Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-14-2007, 10:54 PM
roadworriar is on a distinguished road
Unhappy leadwell mcv-550
Hi wonder if anyone is able to help, i have a leadwell MCV-550 machining centre and had a bad power surge a few days ago and now the tool changer will not function properly.
It removes the tool from the spindle indexes to the next tool required but will not insert it into the spindle.
I'am sure it is to do with the diagnostic parameters one of them is incorrect does any one know where i can obtain alist of the parameters to suit this machine.
Old 10-15-2007, 08:46 AM
outctrl is on a distinguished road
leadwell
sounds like it does not see the unclamp switch
Old 10-15-2007, 11:26 AM
valco is on a distinguished road
We have a Leadwell SV500 that has toolchanger problems sometimes. We put it into a manual ATC trouble shooting mode by changing Keep Bits K5.4 and K5.5 from 0 to 1. By doing this you can push the Start button and it will step through the ATC routine. It may be different on yours but there should be an ATC troubleshoot mode that is similar. When you do this check your X bits for the ATC position to see if the sensors are reading properly. On ours they are as follows
X1004.3 Arm motor stop postion
X1004.2 Clamp/ Unclamp Postition
X1004.1 Orginal Position
X1004.4 Arm stop in middle position
To adjust the distance in Z between the spindle and the tool arm we modify the value for parameter No. 1850 until it is perfectly matched.
To change the position in the software for the clamp unclamp postition we modify parameter No. 4077
If worst comes to worst you can take the tool arm off and put it back on and realign it.
CHECK THE PROPER BITS FOR YOUR MACHINE FIRST BEFORE CHANGING ANY OF YOUR PARAMETERS. Our machine is probably different.
I hope this helps and good luck.
Eric
Old 10-15-2007, 02:32 PM
bruno278250 is on a distinguished road
Leadwell SV500
This may sound dumb but have you completely disconnected the item, waited a minimum of 60 seconds then reconnected? Sometimes it is the little simple things that work.
Don't forget to disconnect EVERYTHING that is hooked up to the componet, even a ground wire.
This may not work but couldn't hurt. Good luck.
AL T
Old 10-15-2007, 10:16 PM
L. Sakthivel is on a distinguished road
Check the Proximity sensors in ATC & Check the bits ON corresponding to the each switch
Old 10-22-2007, 05:34 PM
Thank's guys,
managed to get it sorted, was a timer parameter that needed to be set.
Leadwell LTC 20P ELGT General Metal Working Machines 1 06-05-2007 05:40 PM
Leadwell VMC?????? Fudd General Metal Working Machines 6 02-13-2007 09:18 PM
Need post. Leadwell T26, Fanuc OT naytep GibbsCAM 1 12-13-2006 12:50 PM
Leadwell CNC machines ddanutz General Metal Working Machines 4 11-09-2006 04:23 PM
MCV-OP Leadwell???? bdrmachine General Metal Working Machines 2 02-15-2006 08:35 PM
