Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-13-2007, 09:17 PM
Nick1030 is on a distinguished road
Which end mill?
What do you think is the best choice for doing a shallow, concave pocket. It is about 34"X34" and only about 1/8" deep. We are considering a 2" ball end mill or a 2" flat end mill. However, if you have a better idea, it is appreciated. The pocket is being cut into a composite material with a 5 axis router. Any opinions are greatly appreciated.
Old 10-15-2007, 02:36 PM
bruno278250 is on a distinguished road
Which end mill?
Have you thought of using a flycutter set at an angle (moving the head at a drastic angle) and lowering it down until the width is matched?
AL T
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-12-2009 12:11 AM
Coming Down to the Taig Micro Mill or Grizzly Mini Mill. SpeedsCustom Taig Mills & Lathes 15 01-23-2009 12:14 AM
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 08:56 PM
