| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| anilam 3300 mk hard drive died Hi all Does anyone know how to install anilam software onto a new hard drive from scratch.we have a anilam 3300 mk control but the hard drive has just packed in.Can anybody help please Neal |
| Hard Drive Replacement Hi Neal, I can't speak for the UK but here in the USA you can just call Anilam and their Tech Support department is excellent and could help you with your problem. You will probably have to reload the Paramaters. They can send them to your via e-mail with directions on how to format your new drive for use with your system. If you can't get any help in the UK and can stand the telephone bill just send me a PM and I will give you a contact person and phone number to call in the USA. John |
| An old post, but has anyone succeeded in cloning the hard drive on this machine? Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Before you give up on the hard drive check the power supply voltages. The HD has yellow (12 VDC) and red (+5 VDC) wires for power. Black is 0V. If voltage is low then the computer does not boot properly and it looks like a HD failure. I just went thru this on my 5300 MK. If you have an older PC then try hoking up your dead HD and see if it is actually OK. Mine came up fine and my PC indicated only that the motion board was missing. You also could have a bad battery for CMOS memory. Jerry at Analam has an excellent sheets with instructions for resetting the CMOS data and also for checking and adjusting power supply voltage. If the power supply is bad and won't adjust then Google the part number off the supply. One company does fixed rate repair for $30. JRP |
| I had the same problem with my 3300 but i thouight my hard drive was gone but it was just an adjustment on the power board I had to increase the 5 volt it was reading 4 volts at the hard drive power plug in. This is done by a pot adjustment on the side of the power supply board. |
| PROBLEMS WHIT DISKET CONFIG 1 AND 2 ANILAM 3300 CHEVALIER 2040 I HAVE A 2040 CHEVALIER WHIT ANILAM 3300 BUT I HAVE PROBLEMS WHIT THE DISKETS OF CONFIG DO YOU HAVE IT , COLD YOU SEND ME A FREIND OF MY SENDME A INFO BUT HIS MACCHINE IS DIFRENT CONTROL(6000) HAN DOSEN'T WORK THE ARCHIVE WHIT THE PROBLEM IS CFG THANKS FOR YOU TIME HUMBERTO VARGAS |
| Does anyone backup their CNC's PC hard drive? | WayneHill | General CNC (Mill and Lathe) Control Software (NC) | 7 | 08-22-2010 10:14 PM |
| Anilam 3300 Post for Mastercam X | Bryant303 | Post Processor Files | 6 | 12-10-2009 01:11 PM |
| Help! Building CNC Plasma table and Machinist died! | Crayola | General Metalwork Discussion | 0 | 02-05-2007 03:06 PM |
| Help, my Geckos may have died! | bkkpool | Gecko Drives | 2 | 10-30-2006 02:30 PM |
| Mill drive motor died. | devinchi | Shopmaster/Shoptask | 12 | 05-14-2006 01:47 AM |
