Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-06-2007, 01:12 PM
ZipSnipe is on a distinguished road
Spectralight 0200 controller ?
I,ve recently purchased a Spectralight mill with controller and old 486 pc. Everything works and is actually brand new(was told it was only set up for the school auction) and indeed looks like it was never used. I got everything hooked up and all works. However this is older software control called Spectramill(all dos). Anyway my question is this, can I take to isa card and move it to a not so old pc and download software such as Turbocnc to control it? Or is it the Spectramill controller propeitery to its own software? Have any other Spectramill owners had any luck with conversions? Any input is appreciated.
Old 10-06-2007, 01:39 PM
Al_The_Man's Avatar
I believe TurboCNC is software based through the parallel port. Usually a PC based card has proprietary software to operate, similar to Galil cards, et al.
Is there any thing wrong with the present s/w?
Old 10-06-2007, 01:51 PM
No its just the pc its on is really old and I,m limited to just the Spectramill software on it as there is a password that won,t let me access the rest of the pc in other words I,m stuck in DOS and can,t access windows. Also I have to set up the order of boot up sequence each time I start it.
Old 10-06-2007, 02:16 PM
Al_The_Man's Avatar
If this is the MS-DOS boot, could you not write a Bat(ch) file to sequence automatically?
Old 10-06-2007, 02:54 PM
Well it currently is stuck at startup with a" missing operating system" msg. So do ya think I,m screwed? Can I take this hard drive out and run it as a slave on another pc?
Old 10-06-2007, 03:04 PM
snapman is on a distinguished road
You can move the card to a newer PC with an ISA slot and run it on an Win98 or Win98SE, etc. You will be able to run the software in a DOS window. It won't work with Win2K, XP, or Vista.
You can contact Intelitek tech support and see if they will give you a copy of the windows version of that program and that should work with Win2K and XP as well. It's not "supported" I don't think, unless you upgrade to the PCI card- but it still works, according to their tech support folks.
We had a similar problem with a Prolight mill and lathe and once we made the switch to a newer PC and then installed the Windows version of the basic motion control software it was like night and day.
Hope that helps.
Old 10-06-2007, 03:07 PM
Also, I should add- the DOS software is not bad at all once you get used to it. We also have a Prolight 2000 that is DOS based and we run it from Win98 installed on a laptop and it's great stuff. Of course, for that mill it's also the only stuff so that is a good thing.
Old 10-06-2007, 03:10 PM
Thanx I was thinking I could do it. As I have found that most answers for a "missing operating system" message involve reloading the operating system which in turn I believe would wipe out the software. But then again I think if I move the HD to a newer pc(running windows98) it will want to reformat the HD. I,m I right?
Old 10-06-2007, 03:16 PM
Good point. There used to be a page on their website that allowed download of the DOS software versions- you can try Google and see what comes up. I will look around as well because I might have the link somewhere although I can't locate it off hand.
Old 10-06-2007, 03:33 PM
Thanx Snap, I,ve tried almost everything to get it to post to the bios, it has no battery to reset(or least I can,t find it. I pulled the case cover off the pc and its as clean as a whistle on the inside. Well I want to switch it over to the new pc so lets see what happens.
  #11   Ban this user!
Old 10-06-2007, 05:42 PM
Here is the link but I only see Windows versions of the software. I am sure I have seen the DOS versions for download somewhere but will have to dig around some more.
I would definitely call Intelitek and see if they will give you a link to download the bare bones Windows version of the motion control software though- it's nice stuff.
  #12   Ban this user!
Old 10-06-2007, 06:09 PM
What link?
spectralight 0200 pci expansion card billy b Benchtop Machines 1 07-10-2010 12:02 AM
spectralight 0200 vegasrndll Benchtop Machines 3 10-29-2007 05:27 PM
spectralight 0200 mill(sherline) vegasrndll Benchtop Machines 0 12-27-2006 12:24 AM
spectralight 0200 vegasrndll Benchtop Machines 0 12-16-2006 08:24 PM
spectralight 0200 mill??? jclif CNCzone Club House 0 09-19-2006 10:03 AM
