Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 09-27-2007, 12:47 PM
mr_electrician is on a distinguished road
Help with FANUC 0i-Model A (servo parameters)
Hello, I have a KIA superturn lathe with a Fanuc 0i-Model A control screen. I am trying to fugure out how to set the parameters for an over torque on my Z axis. I can get to the screen that I need but I am not exactly sure what I am looking for. Below is what appers for the Z axis.
FUN.BIT 00010000
LOOP GAIN 3000
TURNING SET 0
SET PERIOD 0
INT.GAIN 203
PROP.GAIN -1821
FILER 0
VELOC.GAIN 256
ALARM1 00000000
ALARM2 01001011
ALARM3 10000000
ALARM4 00000000
ALARM5 00000000
LOOP GAIN 0
POS ERROR 0
CURRENT% 40
CURRENT AMP 10
SPEED RPM 0
Where and how would I set up an over torque alarm for this. Any help is greatly appreciated.
Old 10-09-2007, 10:54 AM
Hmmmmmm?
There has to be someone in here that knows how to do this.
Old 05-29-2008, 02:28 PM
Leksvil is on a distinguished road
You will find that when the servo parameters was initiated, that the torque levels will be set to which fanuc motors are fitted. (the parameter for the torque alarm is 2060 (TQLIM)). By the way the screen you are showing is just the servo parameters from the soft keys, this will allow you to touch just the surface of the digital servo parameters. Good luck my friend.
Well I've never seen it do that before!!!!!!!
Parameters for YAM CK-5, Fanuc 10T gisab General Metalwork Discussion 1 12-07-2009 03:39 AM
Powermate H servo parameters Mike Ball Fanuc 0 05-15-2007 12:01 PM
Fanuc 3M Parameters nastek Fanuc 9 12-29-2006 08:35 AM
Fanuc 18T - Parameters pinguS Fanuc 7 04-11-2006 07:20 PM
Fanuc 2T Model-A Parameters jeffascher Fanuc 0 12-28-2005 01:51 PM
