Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 09-12-2007, 04:27 AM
praest is on a distinguished road
Question Contouring problems Heidenhain 155
I have been milling a kontour on stainless plate 75x12 (all measures are mm)
It’s been working fine, but when the mill is about to finish the arc, it’s not completly round.
It’s not a problem for anyone but me. Any suggestion to a solution.
My machine is a abene VHF 40 CNC and Heidenhain 155,
I also suspect that the radius compensation is calculating a bit wrong, had to move center 1mm to get the measurement correct.
CEAndersen.dk :specialty production in stainless steel
Old 09-12-2007, 08:09 AM
bborb is on a distinguished road
Could you post the program (g-code)?
What dia. tool are you using?
What is in your offsets for this tool?
Old 09-13-2007, 03:48 AM
Code used Heidenhain plain lauguage programming
Tool def 1 L=0 R=6
Tool Call S=70 (ca. 700 rpm)
L X 500 Y-85 Z 1 F3000
L Z -13 F3000 M13
L X 485 RR F3000
L Y-65,784 RR F100
CC X 495 Y-37,5
C X 485 Y-9,2157 DR- RR F100
L Y 2 RR F100
L X 500 R0 F3000
L Y 50 F3000
the dia. of the tool is 12mm, I'm doing the countour once at full depth.
There's no funny noises, chips looking fine
Old 09-13-2007, 08:40 AM
Your
CC X 495 Y-37,5
is probably not accurite, its supposed to be the coordinates of the center of your circle/arc your trying to achieve.
Old 09-14-2007, 01:19 AM
from the end of the piece to the buttom of the arc, there should be 20 mm, and the radius of the circle is 30mm, so I think the CC is allrigth, but
I had to program it CC X496 Y-37,5 to get the measument ok
The attached file is the drawing
Old 09-14-2007, 03:32 AM
Ah, my bad.
Program looks ok dimension-wise.
For grins and giggles, change R=6 to R=6.5 and cut a fresh piece, then change back to R=6 and recut same piece. This should make your recut a "skim cut" with minimal tool pressure. If you get the same results then the problem isn't in your program.
Old 09-14-2007, 04:13 AM
Thanks for the help and inputs. Apreciate any contact, cos I'm CNC department at the shop
I'll try next time to cut it twice using 2 R-values
Old 09-14-2007, 04:30 AM
JohnA is on a distinguished road
If it helps, after changing the R6 to R+6 and running it on my Cutviewer programme ( www.cutviewer.co.uk ) the file looks ok. See attached.
Where is it looking wrong?
0 BEGIN PGM 123 MM
1 TOOL DEF 1 L=+0 R=+6
2 TOOL CALL S=70
12 L Z+2,000 R F9999 M08
3 L X 500 Y-85 Z 1 F3000
4 L Z -13 F3000 M13
5 L X 485 RR F3000
6 L Y-65,784 RR F100
7 CC X 495 Y-37,5
8 C X 485 Y-9,2157 DR- RR F100
9 L Y 2 RR F100
10 L X 500 R0 F3000
11 L Y 50 F3000
96 STOP M02
97 END PGM 123 MM
Old 09-14-2007, 04:46 AM
It's just at the end of the arc (about 14-15 degrees before the end), just when the mill is commimg free of material, overlength is 1mm.
I suspect that you'r solution will work out fine
I'll guess my next problem is translation off words off the trade from danish to english *lol*
By the way, how do you get the pictures in the text??
Thanks again
Jens Præst
Old 09-14-2007, 05:12 AM
Good, hope it works.
To get the pictures in the text use attach & upload them first and then click on the file to insert, in this case attach.bmp Name:  attach.bmp
  #11   Ban this user!
Old 09-14-2007, 06:42 AM
Cutviewer
Could I use Heidenhain plain launguages in the cutviewer program that you use John??
  #12   Ban this user!
Old 09-14-2007, 06:52 AM
Yes you can.
HELP!! Heidenhain PC interface Problems servocontroller Bridgeport and Hardinge Mills 4 06-11-2009 07:05 AM
Heidenhain, Bridgeport TNC150 problems! mossy Machine Problems, Solutions , Wireless DNC, serial port 4 10-01-2008 02:08 PM
Fadal 4020 3d Contouring Problems eric_99 Fadal 9 02-05-2007 06:19 PM
contouring help rbest27 Surfcam 2 02-02-2007 10:14 AM
Heidenhain programming problems lt1pat General CNC (Mill and Lathe) Control Software (NC) 1 03-12-2006 11:28 AM
