Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 08-29-2007, 01:55 AM
XRACERJB is on a distinguished road
Smile Need help with IF ,THEN,AND GOTO USING COMMON VARIABLES.
Can anyone give me a sample prog.using IF,THEN,AND GOTO as counters
using common variables.I want to get away from sub-prog's. lots of short runs
and i think this would save time.only one prog to load,read,etc.
any help would be greatly appreciated.
J.B.
Old 08-29-2007, 07:58 AM
cogsman1 is on a distinguished road
Samples
Here are some samples that I use.
IF[#552EQ666]AND[#547EQ666]GOTO731
IF[#587NE4100]GOTO500
IF[#591LT10]GOTO118
WHILE[#108GT[#109+#110]]DO1
#108=[#108-#109]
M98H#502L#111
END1
#180=[#571/SIN[90-#570]]
#180=[[#180*TAN[90/2]]*2](#7/D)
#181=[[#557/2]/SIN[45]](#5/J)
#182=[#571*TAN[[90/2]-#570]]
#183=[#571*TAN[[90/2]+#570]]
#183=[[#182+#183]/2]
#184=[#181-#183]
#183=[#183-#182]
(milling interpolation)
G12.1
G17
G0U-[[#556-#550]/2]Y[[#557-#550]/2]
V-[.039-[#550/2]]
G98G1Z#525+.012F4.
Y-[[[#557-#550]/2]-[.039-[#550/2]]]
G3V-[.039-[#550/2]]U[.039-[#550/2]]R[.039-[#550/2]]
G1U[[#556-#550]-[[.039-[#550/2]]*2]]
G3U[.039-[#550/2]]V[.039-[#550/2]]R[.039-[#550/2]]
G1Y[[[#557-#550]/2]-[.039-[#550/2]]]
G3V[.039-[#550/2]]U-[.039-[#550/2]]R[.039-[#550/2]]
G1U-[[#556-#550]-[[.039-[#550/2]]*2]]
G3U-[.039-[#550/2]]V-[.039-[#550/2]]R[.039-[#550/2]]
G1Y0
U[[#556-#550]/2]
G0G40Z-.05
G13.1
Old 08-31-2007, 09:08 AM
JMS4287 is on a distinguished road
Here's a quick Example of a palletizer postioning prog.
(#616= current row position)
(#619= total # of rows per pallet)
O8101(PALLET COLUMN COUNT PROGRAM)
N2001
IF[#616GE[#619*2]]GOTO2002
#623=#616
#620=#621
IF[#616GE#619]THEN#623=[#616-#619]
IF[#616GE#619]THEN#620=#622
#617=#620-[#623*#618]
#1132=BCD[#617*10.]
#616=#616+1.
M99
N2002
#616=0
M16
GOTO2001
GOTO Z button TMaster Mach Mill 10 05-30-2009 08:18 AM
Goto Z's button... also the @#$%#$% wizard... InspirationTool Mach Mill 2 04-01-2007 10:54 PM
System variables jorgehrr G-Code Programing 8 02-18-2007 08:26 PM
G65 local variables help FanukRC G-Code Programing 7 07-25-2006 07:00 PM
Common?to Most Surfers Bear Fadal 1 01-22-2006 03:13 AM
