Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 08-21-2007, 11:43 AM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Question M Code for Tailstock?
Does anybody know if there is an M-Code that can extend/retract my tailstock. I have a Fanuc 10 control. I know that M-Codes are usually different from machine to machine, but if anyone knows a generic M-code or one they use or the parameter to change to set an M-Code for this, that would be great. Thanks.
Old 08-21-2007, 01:23 PM
M-man is on a distinguished road
We got some moris with 10, and the uses m24 and m25.... On our other fanuc controls the same m code starts the chipconveyor... Try them..
Old 08-21-2007, 01:33 PM
Boots is on a distinguished road
on our Lathe we just have a switch to toggle for extend and retract but in the program it's automatic and it's binary code. Our Mills just have a hand crank to feed out and in but we could have ordered and air operated tailstock (with foot switch) but it was too much more money. You didn't state if it was lathe or mill with a 4th axis rotory indexer with a tailstock.
Old 08-21-2007, 01:55 PM
I will try the m24/25
Old 08-21-2007, 01:58 PM
Old 08-21-2007, 02:00 PM
Oh, sorry. I have a lathe with a hydraulic powered tail stock. It is extended and retracted using a toggle switch. The problem is that the program I am running requires the tail stock be extended during certain operations and retracted during others. As of now, I am using an M0 and manually hitting the switch when needed. I have heard that there is the possibility of an M-Code that could achieve this same effect. I tried the m24/25 with no luck.
Old 08-21-2007, 02:08 PM
I'm not that familar With the Fanuc lathes but it would seem to me there should be a code for that to be introduced while writing the program. Is your control conversational?
I uses tailstock for the same operation, hydralic tailstocks can be operated both with footswitch and with program.. I uses m78/79 on the 18IT, but that is machine spec and will prob not work for you. WHo is the machine builder?
Old 08-21-2007, 02:17 PM
star-turn is on a distinguished road
what make make is your m/c - it does vary make to make.
you could try M12, M13, M14, M15 each in turn in MDI - this set moves the tailstock forward/back and activates quill out/in
M78/M79 is also a good bet
ST
Old 08-21-2007, 03:13 PM
Alright guys, M12-15 no go, n78-79 no go. Its a Wasino lj-103m (older model, going the way of the dinosaurs) with a Fanuc 10T control. And it is not conversational.
  #11   Ban this user!
Old 08-21-2007, 03:51 PM
whey hey, lets go through the complete list!!! try M50/M51 or failing that have you an operators manual with the m code list ( not the yellow fanuc book )
ST
  #12   Ban this user!
Old 08-21-2007, 03:55 PM
Unfortunately, all I have is the yellow fanuc book, both the Operators manual and maintenance manual and m50-51 has no effect.
tailstock advance code nitrosnfr General Metalwork Discussion 1 08-29-2007 01:44 AM
tailstock won't extend burnin daylight Daewoo/Doosan 0 03-19-2007 04:35 PM
Right pressure for tailstock jani General Metalwork Discussion 12 03-05-2007 11:45 AM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 06:20 PM
power tailstock Runner4404spd Mini Lathe 5 08-28-2006 08:27 AM
