Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 07-24-2007, 06:22 AM
DaSnake is on a distinguished road
Check my math for a Knee Mill conversion...
I am not sure if this is the correct place to post this.
If not feel free to move it to the correct place
(this forum is MASSIVE)
I have a Hurco KM-1 cnc knee mill.
These are the specifications according to the owners manual.
200 line quadrature encoder
0.200 travel per rotation of ball-screw
250 IPM original high speed
So if I understand correctly, using the factory encoder in quadrature would
take 800 steps on a gecko style drive to rotate 360 degrees.
With Mach 3 limited to 45k pulses per second (I assume the extreme upper limit)
Then 45000[pulses per second] * 60[seconds] = 2700000 pulses per minute
2700000/800[steps per rev] = 3375[RPM]
3375 * 0.200 = 675 IPM
I remember somewhere, somebody stating that if I went to gecko/rutex....
that I would loose some speed on a simular setup.
Do the above numbers look correct. And FYI I do not expect to be able to
go faster. I just dont want to go much slower....
Old 07-27-2007, 09:37 PM
Mickey_D is on a distinguished road
I converted a Bridgeport BOSS machine that had 18x12 of travel. I used some 512 count encoders that I had and with an old laptop driving it I was getting 140 IPM rapids/cuts in plastic and that was plenty. That big table moving around that fast will make you a little nervous. Without a tool changer on the machine the lack of a super fast rapid is not going to make much of a difference in your part times. You switching tools are going to be the bottleneck.
please check my math project5k Benchtop Machines 12 07-30-2007 12:57 PM
Can someone check my math? DC Power supply. pfarber General Electronics Discussion 2 11-30-2006 12:43 PM
Induma Knee Mill CNC Conversion TommyL Knee Vertical Mills 0 05-21-2006 10:24 PM
Check my math!!! (Please) Hack General Electronics Discussion 19 04-15-2006 06:18 PM
knee mill conversion mtechserv Knee Vertical Mills 6 12-04-2004 12:30 PM
