Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 07-04-2007, 10:03 AM
Danii is on a distinguished road
Question FANUC 20-FA RS232 help required..
Hello all,
I am working on a cnc machine of MAKKINO which has FANUC 20-FA control system installed. I have a very few how now of these type of systems. It is working if i give it commands from the pannel available on controle system but i want to send the GCode from pC using rs232 to it. I tried it with defualt setting of rs232 i.e
4800 baud
1 startbit
2 stop bit
Controller doesnt seems to receive the correct data from pc and it also not sending any data to pc. The Alarm Error #86 appears always. Also I am not much awear of the rs232 setting on Fanuc contorller side.
Please if someone can guide me where i am doing wrong. Ihave made simple straight cable for rs232. If some one have some metrial about rs232 setup or have experience of FANUC 20-FA with BobCad then please do share it soon.
Regards
Adnan Ahmad
www.technocrafts.com
Old 08-18-2007, 11:29 PM
rsmachine is on a distinguished road
Your first problem is you cannot use a straight cable to send and receive programs, you must use a cross over cable for receive and transmit. Then you need to setup your software to match the settings of the machine.
Sean
Old 08-31-2007, 01:30 AM
gm3211 is on a distinguished road
Adnan,
The alarm is based on the cabling problem you have as stated. You need to use a null modem cable to communicate to the CNC. Once in place, match the baud rate on both ends, data bits, stop and parity.
If you want to purchase a cable that is ready to go for the CNC, visit our website.
Greg Mercurio
Shop Floor Automations
www.shopfloorautomations.com
Old 09-01-2007, 10:37 AM
Thanks for reply
I have used the null modem cable and now I am able to send and receive nc files to and from PC. Now all i want to do is DRIP Feed, Can any one tell me the procedure of it.
Regards
Adnan
Old 09-20-2007, 07:21 PM
You will need to purchase a BTR card to make this drip feed, DNC.
We do sell them on our website: www.shopfloorautomations.com
Cost is $1400.00
Greg Mercurio
619-461-4000 ex 1001
Old 09-21-2007, 12:11 AM
Hi all,
I was able to run my machine in drip feed. I have successfully used Null modem cable with software flow control to XON/Xoff and freedom DNC software. My machine is working fine now. If any one need information then tell.
Bye..
Danii
Miyano 34 with Fanuc Controller - Paramaters required andysimm2000 Fanuc 4 05-05-2007 09:49 AM
info required about fanuc macro programming sinha_nsit Fanuc 11 04-06-2007 09:13 PM
Help required for Fanuc 0t gricha Fanuc 6 03-23-2007 01:31 AM
Anilam Crusader Series M RS232 help required.. Danii General CNC (Mill and Lathe) Control Software (NC) 3 05-25-2006 01:55 AM
FANUC Servo Amp Manual required woodglass Commercial CNC Wood Routers 0 09-09-2005 01:44 PM
