| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
Hey guys, thanks for looking, I need some help finding a software that will let me engrave serial numbers from say 1 to XXXXX. I got my self into this trouble after I engraved some PCBs for a friend using DeskCNC and now he wants me to do this on thousands. If there is something I can use I wouldnt mind building a 4"X4"X1" micro cnc just to do this, should be a good project. Waiting for ur comments. Cheers Dev |
| You may try deskengrave (use google) for your text needs. It's very simple and free. And oh by the way, did I mention that It's free!!! Enjoy Bill
__________________ billyjack Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>) |
| Thanks Bill, but the deskengrave dosent create toolpaths for serial numbers, I did however find something similar to what i need at 2linc.com, only thing is that its $350 or something, let me try my luck finding something cheaper or maybe even free, if not, I guess I will have to buy this. Dev |
| I think I remember reading that Turbo CNC(TCNC) was capable of doing serial numbers, you might want to ask on their Forum. http://www.dakeng.com/index.html This is from the TCNC manual. I don't know if it will do what you want. Set Cycle Count You can set the cycle count to any number from 0 to 99,999 with this menu option. This is typically used for keeping track of production volume, and in some cases for establishing part serialization. Note that each time a g-code file is run to completion (Single Cycle, Piecework or Automated modes), a “joblog.txt” file is updated in the current directory with the time/date stamp, cycle length, and the file name. Keeps track of your billable machine hours. Here's something else to check: http://www.luberth.com/plotter/dwtechniek.htm Last edited by jimini; 06-27-2007 at 10:37 AM. |
| 2L inc. has an engraving program that will do serial numbers http://www.2linc.com/engraving_software.htm oops i see its already posted |
| I thought that (once I get my mill setup properly) I'd use it for logo/model/serial numbers as well. I was thinking though that it should be relatively easy to write a C program under Linux to generate the g-code for sequential serial numbers and put a pause between them (requiring my action, like a tool-change does) so I could change the part. |
| Its cool if you can see through it cnczoner, I would have done it if I hadnt stopped writing codes 7 years back, but just in case you do write something like that, put up a compiled executable file here, for everyone to bless you for. Cheers Dev |
| I think it would be easy, even though I have not programmed C in a while. (I do mostly microcontroller assembly nowadays). Not a problem though, but I use Linux for these things cause I can type code in any text editor, compile and run. Windows coding requires me to purchase some development tool that will first ask me to setup a project, setup the environment with window sizes, dialog boxes, etc, then a week later I get to actually write code. Ugh! So any executable I write will be unix-code, or I don't mind giving out the C-code. If someone knows of a simple Windows scripting-like or interpreted code development system, let me know. I can do C or Basic. As I'm still new to machining/CNC though, I'll need some quick assistance on one thing... how does code M6 work? I know it's for "tool change", but how exactly does it work? Does it bring the machine to a home position and wait? Does it just pause in place (and how does the operator tell it to continue after the tool is changed)? Does it pause for a short time and restart after some specified time? Does it actually just invoke a turret or something to change to the next tool? Here's why I ask... I intend to write the code so that the user enters a starting serial number and amount of numbers to iterate through. Then it will spit out g-code (in a file) to engrave the first serial number, pause (using the M6 command), then do the next, pause, etc. Scaling can be done with the controller software, or I can perhaps add scaling later. The more I think about this, I can't see why I couldn't get this done in just a few evenings. Cheers, -Neil. |
| Fadal L9201 Serial Engraving | LP-CNC | Fadal | 5 | 10-25-2009 01:49 AM |
| Posting sequentiol serial numbers | NateG | Engraving Machines | 3 | 06-22-2007 06:09 AM |
| Round Numbers | stampman | Fanuc | 4 | 09-05-2006 06:12 PM |
| RFQ - 2 part numbers | mcmmach | Employment Opportunity | 1 | 05-19-2006 10:18 AM |
