Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 06-24-2007, 02:58 AM
twocik is on a distinguished road
USB jump drive Help??????
Hello,
Can anyone here help me with my jump drive usb problem.. ???
I'm trying to introduce a usb jump drive into my CNC workflow. I can't seem to get my 1999 POS computer to recognize my usb jump drive. The hard drive was replaced. I bought a new used hard drive from goodwill a few months back, which works fine. I think the USB drivers on the HD are not all there. I don't have a copy of windows 98se, so I can't reinstall. When I plug in a USB keyboard it works, so I know it's not the USB ports. I believe it's a drive problem.
When I plug it into the back of my pc, it does nothing. The USB jump drive I'm using is (below). I've followed the online instructions and nothing seems to work.
http://www2.pny.com/256MB-USB-20-FLA...-P1884C53.aspx
For software I'm turboCNC and everything is controlled thru dos only. I'm running win98se and can't seem to figure this out. I'm a non pc guy, so please be easy on me.
Chris
Old 06-24-2007, 03:51 AM
Kipper's Avatar
Kipper is on a distinguished road
Hi if you have a COA for your POS (<Point Of Sale? ) You could legally "borrow" an install disc from a friend and reinstall....Win98 was so reliable after having not used it for 5 years I can still remember the serial number of mine lol
Keith
Old 06-24-2007, 05:32 AM
Bubba's Avatar
Bubba is on a distinguished road
Are you trying to use the jump drive through windows or dos?
If windows, you have to install the correct drivers. If dos, again it is a driver problem. However this can be solved as there are a set of files in the turbocnc group over at youhoo with instructions on how to do it in dos. However, I have found the jump drive HAS to be inserted before booting. It will not hot swap. Works in my shop for Turbocnc and I have used a couple of different jump drives.
Art
Old 06-24-2007, 06:56 AM
ger21's Avatar
Try installing the driver for it.
http://www2.pny.com/support/support_...=1057&TypeID=5
Old 06-24-2007, 09:51 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
I don't think win98 supports "USB 2.0" out of the box.
USB 2.0, was done in 2001. I bet your pc has "USB 1.1" on it.
Do like ger21 said get the drivers from the manufacture.
Direct Link (driver/zip):
http://www2.pny.com/support/media//F...r_Rev13_v1.zip
You could have got a 1gb stick for $1.00 more than the one you bought?
http://www.walmart.com/catalog/produ...uct_id=5334256
Old 06-24-2007, 03:45 PM
"Hi if you have a COA for your POS (<Point Of Sale? )"
Piece Of Sh*t. Sorry I should have been more clear.
I'm using two computers in my workflow. One for designing (it being brand new and faster for ram preview), my second computer is to run Turbocnc .
1. Dell laptop (for designing and interpreting Gcode to CNC file)
2. POS Computer (to read the Gcode file and break it up for the steppers to my milling machine).
Thanks guys I really appreciate the help!
Old 06-24-2007, 03:54 PM
Bubby
"Are you trying to use the jump drive through windows or dos?"
I would like to use it thru windows, but if I could use it thru DOS that would be great!!
Ger21
"Try installing the driver for it.
http://www2.pny.com/support/support_...=1057&TypeID=5"
I've tried, but it asking me to open it with a program. I've tried a few that look like they could open it, but no go. I know this is really confusing.
switcher I believe you're right, because I'm not having any luck at all with this machine. The driver that you recommended to use I'm not sure I'm installing it right. There's three files, first one says
1. musb6E.inf
2. PU20DISK.PDR
3. PU20SYSD.SYS
Old 06-24-2007, 04:12 PM
Bubba's Avatar
I am using the drivers for DOS from the yahhoo group and they have worked fine for the two different jump drives that I have. You have to read (then re-read) the instructions to get it to work.
After about three times, I finally understood what they were saying and now all is well! Matter of fact, I can no longer boot to windows on that machine. It is strictly DOS and for a "hard drive" I use a CF card. solid state and haven't lost a drive in months like I was before. My shop is conditioned by whatever the weather is here (Cold and humid in the winter and Hot and humid in the summer:{(
Art
Old 06-24-2007, 04:17 PM
Bubba I'm only seeing the zip file, no instructions? I'm really a non-PC guy, is it really that hard to understand? I know alot about macs, but PC's are very new to me.
http://tech.groups.yahoo.com/group/turbocnc/files/Usb/
Old 06-24-2007, 04:26 PM
Now here's something weird, in dos mode when I run Turbocnc, sometimes the mouse works and sometimes it doesn't. I never thought of maybe my hard drive might need to be clean up a little. There are files from the last owner still on there. I've delete little things like the internet files, icons, games, etc.., but didn't want to touch anything else. I'd really like to start from a fresh start with win98, but I don't own the program and can't find it anywhere. Any suggestions
On a Mac we have a first aid option that will clean the HD, does a pc have anything like that?
  #11   Ban this user!
Old 06-24-2007, 07:39 PM
Kipper's Avatar
You're in luck!! there's a thing called an OS install disc it has pretty holograms and such on it and says Microsoft Windows 98 on it too failing that a lot of PC vendors placed (stole your hard drive real estate) a separate restore partition on the drive and you could reinstall from there. All things being fair you shouldn't reinstall an OS you don't own ([invisible ink]I couldn't care less as I don't have shares in MS[/invisible ink]) the OS should be around $5 on ebay that way you get the diskette and the CD and bobs yer uncle and fanny's your uncles live in lover...< oh how the times have changed...she would have been your Aunt 20 years ago...
admin needs to fix the invisible ink bb code
Keith
Old 06-24-2007, 07:54 PM
Switcher's Avatar
Moderator
This website will scan your pc, of your system drivers
and compares those to a database of over 90,000 drivers
to see if your system has the latest drivers.
1) http://driveragent.com/
2) http://driveragent.com/faq.php
(I havn't tried this, just found the website, might help).
Inlay artist wants to jump into cnc 1bordeaux Musical Instrument Design & Construction 52 04-03-2006 07:20 PM
Inlay artist wants to jump into cnc 1bordeaux Commercial CNC Wood Routers 23 03-17-2005 01:11 PM
Forum jump CNCadmin CNCzone Site News and Contests 0 04-06-2004 09:58 PM
Got a jump start on building materials for my CNC Router Darren_T DIY-CNC Router Table Machines 3 11-16-2003 07:13 PM
