Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 06-15-2007, 09:46 AM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Question Fanuc vs. Fadal
Hey guys. Our shop is interested into buying a new used VMC. We found one that falls in our price range but it has a Fadal control on it. Everything we have used in our shop to this point has been run with a Fanuc Control. Can someone tell me the differences I can expect to see between these 2 controls. Is it an easy transition or will I essentially have to "relearn" programming. Any info would be great.
Old 06-15-2007, 01:11 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Should be easy, Fadal format 2 is more or less Fanuc emulation.
I don't think format 1 is a whole lot different either.
www.integratedmechanical.ca
Old 06-15-2007, 03:55 PM
Thanks for the feedback Darebee, much appreciated!
Old 06-16-2007, 12:12 AM
Sprew is on a distinguished road
Not to much difference at all, really. I use the same Fanuc postprocessor for Fanuc (obviously), FADAL, and HAAS. A few changes, like E1=G54, Dump the 4th Axis null, & my older FADAL likes its R's to be R0's. My newer FADALS dont mind it either way. That is really it. Piece of cake.
The subprogram structure can be quite different, but who uses those.
Old 09-10-2007, 07:32 PM
steer is on a distinguished road
We have both, Fadal and Fanuc. Fadal fomat 2 is pretty much the same as fanuc. Format 1 is Yasnac.
What is your best mod you have done to your Fadal carbidecraters Fadal 51 05-13-2008 11:43 PM
Using a non-Fadal Rotary Table With a Fadal VMC Fudd Fadal 4 03-01-2006 09:46 PM
Fadal 18I Fanuc Control bug chipsahoy Fadal 2 02-12-2006 08:11 AM
Fadal with Fanuc Control REVCAM_Bob Fadal 0 11-03-2005 09:33 PM
Fadal with Fanuc control?? REVCAM_Bob Fadal 1 10-01-2005 10:34 AM
