Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 06-04-2007, 10:26 AM
mr_electrician is on a distinguished road
If condition
Hello guys, I usually program plc's, so when it comes to CNC programming I have issues!! Is there a way of having an "if" condition. I want the lathe to operate like the following,
if the chuck is unclamped and cycle start is excecuted, then go to infeed conveyor. If chuck is clamped and cycle start is excecuted, then go to exit conveyor and release part.
Thanks guys for the help.
Old 06-04-2007, 01:16 PM
Al_The_Man's Avatar
Do you have Macro/parametric programming on the machine?
e.g. http://www.cncci.com/resources/param...rogramming.htm
Also in many controls, various machine status can be read from dedicated internal registers
Old 06-09-2007, 10:44 AM
g-codeguy is on a distinguished road
It always helps to include the name of the machine, the controller it uses, and options you have (such as Macro B capability). You might even find someone with the same equipment who would be willing to post an example for you. I know I would if I had the same machine, and knew the answer.
Pretty hard to give someone a concrete answer when you are guessing. Al_The_Man is one of the good guys on here. Give us some more information, and Al (or someone else) will probably supply an answer.
a.g.e. 3, z axis runaway condition lesnesman Bridgeport and Hardinge Mills 5 11-26-2005 08:36 PM
Cutting condition.... please !!!! speedhawks Laser Engraving & Cutting Machines 3 11-08-2005 02:31 AM
