| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
Heya guys, which CNC package cuts 2D pockets the most intelligently, with the least amount of running over paths that were already cut, and with the least Z repositioning moves (for 2 axis cutting)? |
| Are you referring to a design CAD / CAM package, or to a program like Mach3 which sends out step / direction signals to move the various axis? The actual paths to cut the pockets is the g-code which is created either manually, or by a program which creates the g-code from a CAD drawing. If the part with the pockets is created via a CAD package, the g-code produced will be in the order that the part is drawn. (First cad line = first cut). However, some CAD / CAM packages that can also produce the g-code files, may have built in algorithms to maximize the g-code and therefore minimize the machine cutting time. Sorry I cannot give you an answer to your question. |
| Try SheetCAM. All CAM programs tend to have some overcut problems even the real expensive ones. The pocketing cut (spiral cut) has worked good for me in the past. The price differential may convience you to give it a hard look. www.sheetcam.com |
| My new TM-1 cuts!!!!!!!!!!!!! | blackhollowmfg | CNC Plasma and Waterjet Machines | 0 | 03-16-2007 08:24 AM |
| More first cuts | CNCadmin | DIY-CNC Router Table Machines | 0 | 11-27-2006 10:00 AM |
| More first cuts | wcarrothers1 | DIY-CNC Router Table Machines | 4 | 11-25-2006 07:19 AM |
| First cuts | wcarrothers1 | DIY-CNC Router Table Machines | 7 | 10-27-2006 11:17 AM |
| First cuts | no priors | General Metalwork Discussion | 9 | 08-21-2006 10:03 AM |
