Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-19-2007, 03:50 AM
Edward Perera is on a distinguished road
Help needed - Emco F1 CNC Mill.
Hi All,
Could some one please help me in programming M99 in my Emco F1, with G02, to mill an arc which is less than 90 degrees. According to the manual, only the J and K values are needed. But when values are being input the machine which I am having requests, for an 'I' value also. The programming comes to an end with the alarm '01', Wrong Radius M99.
Thanks & Regards.
Edward.
Sri Lanka.
Old 04-23-2007, 08:16 PM
spinwheelz is on a distinguished road
I think your machine requires center point programming of partial arcs. The circle center point is always incremental and without + or - signs, and from the start point of the arc onwards using addresses I, J, & K. ( X, Y, & Z respectively) Example: (in X/Y plane) the first block needs the following: G02/G03 dir of rotation, the XYZ values of the endpoint of arc, and feedrate. The next block (M99) you need to describe where the circle center point is in relation to the start point. In this example, only I & J values are needed. You need to figure how far in X from the start point of partial arc to the center point of the arc, using trig, and enter this as "I" value. Then figure the Y distance from start of arc to center point, and this number is "J" value.
I hope this helps, it's very confusing stuff!
Old 04-24-2007, 06:40 AM
Hello Spinwheelz...
I have tried out programming G02/03, and M99 using the center point programming method as you have explained... and it worked... The EMCO Manual was giving a completely a different picture, making use of angles only. ( i.e. J & K inputs are in degrees).
You are right ... it is very confusing...Thanks very much for helping me out..
Regards,
Edward,
Sri Lanka.
Help with Emco F1 mill svon89 Benchtop Machines 14 06-06-2010 04:54 AM
EMCO v10 lathe help needed flht1997 General Metal Working Machines 3 02-07-2007 09:23 AM
Upgradeing a Emco F-1 cnc mill woodythx13 Benchtop Machines 1 10-01-2005 02:30 AM
Emco-Maier PC Mill 30 txcowdog General CNC (Mill and Lathe) Control Software (NC) 0 07-28-2005 10:18 AM
EMCO Compact5 CNC help needed. ESjaavik General Metal Working Machines 5 07-15-2005 01:08 PM
