Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 03-20-2007, 11:22 AM
Txshane is on a distinguished road
Software ideas needed....
I am new to this forum. I have been lerking for a couple of weeks now and just signed up today. I can't seem to find what I am needing help with. I am new to the cnc world. I am the only programmer my company has. We have 2 mills and 3 lathes. The newest is a QT200 640T fusion. We only have several hundred hours on it.
I am looking for some software that will allow me to program from my desk and create layouts/setup sheets per program. Our goal is to network all of these machines to one pc. We use a generic setup sheet now that is lacking to say the least. I have been designing and making tools for years. I use auto/cad and Bobcad/cam now. Mostly for wire EDM work. We have several hundred programs on file that need to be on setup sheets. Problem is that we run the same jobs on 3 different machines that require 3 different setup sheets. Our mills are mostly used for second operation. All of are lathes are just 2 axis machining. Any help or sugestions on software would be great. Nothing that we have will even read the files coming off the Mazaks.
Old 03-20-2007, 12:40 PM
WayneHill's Avatar
WayneHill is on a distinguished road
Hi Txshane,
Welcome to the forum.
First question:
Are you running Mazatrol and / or G-Code on the QT200 640T Fusion control?
It makes a big difference on the software you will need to load and save your programs with.
Wayne Hill
www.codemangler.com
Old 03-20-2007, 01:47 PM
I use both. I don't use g-code unless I have to.
Old 03-20-2007, 01:53 PM
jackson's Avatar
jackson is on a distinguished road
I have 4 lathes and 4 mills what i do is put the set up at the head of the program that way you can have a print out of it and it is in the machine as well it works very well for us if you have 2 different machines just make side notes in the setups, as for linking them you need a good comunication software with the amount of machines you have you can use i com. and get a switch box and just set all your baud rates the same, now if you want to spend the money you can get wireless coms. witch i think is a better way to go i havent forked out the money yet but i plan to "i use Multi DNC for my comunications i like it it has back plot, time est., calculator there are several to choice from
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 03-20-2007, 01:57 PM
holbieone's Avatar
holbieone is on a distinguished road
from what I'm understanding is that you want to be able to post tapes for all machines at once
and have a setup sheet for each machine as well
so an operator can call up a part number and receive the proper tape and setup sheet for the machine being run
is this correct
Old 03-20-2007, 01:59 PM
holbieone's Avatar
do these machines have network capabilities
Old 03-20-2007, 10:44 PM
I just purchased Camlink for the bargain price of five arms and six legs. Any input from current users would be great.
Old 03-21-2007, 01:25 AM
WayneHill's Avatar
Camlink can do the file transfers. We use it all the time.
It costs us six arms and legs. You got a good deal on it
Connect it to a standard PC serial port. Do not try to use a USB Serial add-on box with it.
Wayne Hill
www.codemangler.com
Old 02-25-2010, 11:22 AM
rick_7037 is on a distinguished road
Feature cam post well and supplys all the neccesary paperwork i have camlink and Featurecam and use the cam
Missing X-axis backplates and some other items needed to replace - ideas wanted! ints99 Syil Products 3 12-21-2006 06:25 AM
help with software needed xcphil General CNC (Mill and Lathe) Control Software (NC) 0 06-02-2006 08:05 AM
Planning software needed Traceman Mechanical Calculations/Engineering Design 8 05-09-2006 03:19 PM
EZ-cam, EZ-link software needed pdmech Bridgeport and Hardinge Mills 7 04-14-2006 10:35 AM
old spectralight software needed (MAC) troutguru Machine Problems, Solutions , Wireless DNC, serial port 0 12-14-2005 02:29 PM
