Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 03-19-2007, 09:47 PM
Dave1's Avatar
Dave1 is on a distinguished road
Question What's this stuff worth?
Almost complete 3 axis servo system from a Techno Isle gantry router. Working area was 3 ft x 5 ft. I say almost because the limit switches are gone. It was a running system when removed from service. I have the control box, servos, cables, interface card, software (g-code and native mastercam nci) and a manual. I also have (4) 1" thompson rails and risers with (8) bearings. Probably have some ball screws, not the best but not the worst. Just trying to figure out what the stuff is worth or if it's worth nothing then I'll just hang on to it.
Thanks,
Dave
Schneider Machine
A force of one
Old 03-19-2007, 10:00 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Thanks,
Dave
Need to post pictures from different angles, all electronics, and so on then you can give people a better idea of what you have and condition.
Joe
Mach3 tuning (cuts small stuff fine, but is off on big stuff) jdbaker Mach Software (ArtSoft software) 4 03-15-2007 11:30 AM
For what its worth...FYI jer29_11_13 General Metal Working Machines 0 07-22-2005 09:03 AM
Is It Worth It? FLUTE HEAD LinuxCNC (formerly EMC2) 13 03-13-2005 03:47 PM
welding thick stuff to thin stuff - need advice cross6 Welding, Brazing, Soldering, Sealing 5 01-13-2005 01:39 AM
Worth it CNCadmin Benchtop Machines 3 04-01-2003 11:21 PM
