Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 03-19-2007, 04:04 PM
MartinLogan is on a distinguished road
Cool CNC Setup Template
I am looking for a template to communicate job setup instructions for operators out on the floor. Anybody have something. Thanks
Old 03-20-2007, 05:02 AM
Hursty is on a distinguished road
The PDF files attached show a couple of examples I use for training. You are better off including the data on the part programme and not using them; create a tool library then all you have to do is include the tool number with any length specifications together with the operation description. Using the data sheets only creates more work for you; they are then either lost (or not filed correctly), not updated or covered in oil / coolant etc.
Template Bulider Tazzer Haas Visual Quick Code 9 02-18-2008 02:24 PM
Template digitizer plans bradboldrini Mechanical Calculations/Engineering Design 1 07-30-2006 01:41 PM
VQC Template Builder leggetmachine Haas Mills 3 05-28-2006 07:00 PM
Need template for way covers - Bellows Origami? PEU DIY-CNC Router Table Machines 21 11-30-2005 10:38 AM
